Groaning sound in motor
Fred Valdez
SF Bay Area
Hello,
Within the last few days I'm hearing a now distinct groaning/whining sound from motor area. Last night I decided to pull the serpentine belt, start it and see if that sound was still there. No it wasn't. So it's either the belt or a pulley causing this. I'm buying and installing a new belt today so we'll see if sound goes away.
-fred
Flexpedition
midwest
I proactively swapped out the belt tensioner on my '08 when I replaced the belt a few years ago. Motorcraft part 1l2z-6b209-c and was about $35. The old one was fine but made sense to swap it while I was in there and only added a few minutes to the job.
If you haven't bought the belt yet, I went with a Continental & no issues.
On my last ‘07 I used a Goodyear with a new tensioner I think? The new belt didn’t last long and replaced with a motorcraft which lasted until the end. Most aftermarkets should be fine I just got a funky one.
Fred Valdez
Fred Valdez
SF Bay Area
Any chance it's your power steering pump?
iimagine
well, I'm leaning that way...while swapping the belt I turned all the pulleys that freely spun and saw/heard nothing out of the ordinary. After I put new belt on and started I still heard the groan. It even changed tone when I turned the steering wheel so my guess that's it...it seemed to quiet down a little with new belt (probably a placebo effect). Is this something to worry about in the immediate future? The more I think about it..I hear louder groans./whining in alot of Ford Explorers...so this maybe more normal than I think..
Fred Valdez
Fred Valdez
SF Bay Area
but...with that said...thru searching it also could be idler pulley or tensioner too... it's cheaper to go this route for replacement and if it still groans afterwards, then address the pump...
I’ll just throw this out there, a power steering pump failure is very rare on the 5.4 3V it’s a solid unit. FordTechMakuloco said leaks and failures are rare and most steering issues are shaft related.
Fred Valdez
Fred Valdez
SF Bay Area
yea i did the tensioner because of a vid i saw from him... i think gut is telling me it has to do with the power steering tho... checking to see what i can do before considering replacing it.. maybe replace fluid, check for air in system etc.
Fred Valdez
Fred Valdez
SF Bay Area
gonna try to siphon as much fluid in reservoir later and replace with mercon v atf later today.
Fred Valdez
Fred Valdez
SF Bay Area
Well all...it wasnt what i thought it was...turned out to be a failing alternator...it died commuting home today so i replaced alternator and walaa! Groaning suddenly disappears an suv runs good now...
Fred Valdez
Fred Valdez
SF Bay Area
At least i replaced the serpentine, tensioner and swapped new fluid in ....so did proactive maintenance trying to figure this out..go figure...
