Trail Ridge Tow mirrors and BLIS
HawkX66
HawkX66
Semper Fi!
VA/MA
Thinking of getting a pair of these myself unless there is some other option that adds the power fold yet?
Did you ever add in the amber leds to the non mirror side yet and/or know of any that would fit easily/properly? The nicer one you linked earlier looks like its for under the mirror?
There aren't any power folding yet that I'm aware of. I haven't added the leds to the backside yet. Hasn't been high on the priority list as of late.
richs fishes
Long Island, NY
Fair enough. Chances are if I added the leds to the backside they would end up hyperflashing I assume?
HawkX66
HawkX66
Semper Fi!
VA/MA
What would make you assume that? Because you're doubling up on the same circuit? Hyper flashing is usually an indication of using LEDs where incandescents were used originally. Using LEDs shouldn't cause a problem, but I've been known to be wrong before...
richs fishes
Long Island, NY
Maybe I'm just over thinking it! Not sure why but I did not think the signal lamps in the mirror were LED? Sounds like all I'll need to do if adding the additional signal is tap right into same source as whats going to the signal in the mirror already. Adding in dynamic signals would likely be a bit more complicated?
HawkX66
HawkX66
Semper Fi!
VA/MA
Yes, with LEDs being low wattage, you should be able to just tap in to what's already there for wiring in the mirrors.
x46415
Elizabethtown, KY
I got a pair of these for sale for $200. I can’t post in the for sale section since I don’t have 50 posts. I guess just don’t have that much to say. I’m in Radcliff, KY if interested.
2007 to 2017 Ford Expedition Towing Mirror Set. Power, Heated, Turn Signal, Memory, Blind Spot Detection, Puddle Light, Manual-Folding, Textured Black, Manual-Telescoping. Sold our RV and no longer need them. $300 new.
tophe7d
US
Do the front facing caps just pop off? I've pried on them a bit, but it just wanted to marr the plastic and felt like it was going to break something. Maybe I'm just being too cautious? I'd really like to add some sort of front facing indicator and/or parking lamp for better visibility.
Sent from my SM-G892U using Tapatalk
johnboneske
I have a set of them from AM auto parts and love them! They are on my 2003. I wouldn't ever tow again without them.
