Strange noise from throttle body
rwmorrisonjr
Memphis, TN
I'm getting a strange noise from the throttle body on my 5.4. When I put it under very light load, like in a drive-thru, I'll get a brief "metallic" or raspy sound for 1-3 seconds, like its starving for air or gas, then it goes away. It won't make the noise when I'm already moving or starting from a dead stop, but when I'm idling forward and just touch the gas. I've cleaned the throttle body once, but might need to do it again. It doesn't effect milage or power, but don't want it to grow into something bigger.
coolzzy
Idaho
Could be VCT solenoid too, most noticeable at light throttle in drive or reverse. Some noise is normal. Lots of noise is bad.
rwmorrisonjr
rwmorrisonjr
Memphis, TN
Thanks. Haven’t experienced any of the symptoms (CEL, rough idle, etc.), but I’ll run it down after I check the heat shields. With 143k miles on the truck, this is the first engine noise I’ve experienced.
rwmorrisonjr
rwmorrisonjr
Memphis, TN
Crawled under the truck this weekend and couldn't find any loose heat shields, so I'm ruling those out. It only seems to make the noise under a sudden light throttle, like tapping it in a drive-thru, or when at a constant RPM in a high gear and the transmission won't downshift. It also seems to be coming from the front of the car. Could it be an idler pulley or similar going bad? Going to test those when I get back from my trip Thursday and its a bit cooler out.
rwmorrisonjr
rwmorrisonjr
Memphis, TN
Ok, I was able to get a video recording of the noise. Here's when it happens:
  • In gear under light throttle
  • Around 900-950 RPM
  • Goes away when not in gear or above/below 900-950 RPM
Thoughts are appreciated!
rwmorrisonjr
rwmorrisonjr
Memphis, TN
VCT solenoid rattle, some odd noise is normal. If it’s loud they may need replacement.
EDIT: I disconnected the VCT solenoids and tested the engine again, and no rattling noise. I tested it with in gear and the noise returned. I reconnected the VCT solenoids and revved the engine without load and no rattle.
As I said, it only makes the noise when in gear and under load. I tested for the noise again and it sounds like its coming from the transmission/transfer case area. I don't think its the starter/Bendix since its intermittent and only at that particular rpm range.
Here's a better recording closer to the ground. Will try to get my wife to help tomorrow so I can get a better recording.
