todadamson
The manufacturing date was 5/17/2019. Mileage at the time of the oil change was 1100 miles. This vehicle was equipped with the trailer tow package which has the 400HP EcoBoost V6. The oil pan was metal and the drain plug was metal 15mm hex head unlike a previous version you may have heard was plastic. I thought it would take a long time since I had never attempted one of this type vehicle. The drain plug is accessed under the passenger side. The vehicle was hosted from the jacking points behind the front tires on both sides. I used two 6 ton jacks to stabilize the vehicle, each of which were situated under the front frame and a chock was placed under the rear tire on the driver's side. There is a baffle blocking access to the drain plug area which must be moved. There are 4 screws holding the baffle. The rear most screw on the passenger side should be only loosened so that the baffle can be moved after the other three screws are removed. I placed a wide mouth bucket under the drain plug after hearing that the oil will spurt out in a gush. First I removed the oil filler cap in the engine compartment and when I removed the drain plug I did not notice any difference in the discharge rate as any other vehicle I had ever changed the oil. I used the recommended oil being the Motorcraft blend 5W-30. There were no complications whatsoever. You should wait until the oil has completely drained before changing the filter (Motorcraft 500A) because as has been noted, the residual oil in the filter will discharge from the back of the front baffle and you will probably want to use your bucket to catch the oil from the filter.
