Side Mirror Glass Removal
dcsang
The heating function on my 2013 driver's side mirror isn't working and thought I'd check the connections on the rear of the glass. Any tips on removing the glass from the mirror housing?
D
dcsang
I searched and didn't see that post, thanks for the reference! Hopefully the heated mirrors will have a simple solution.
marlinpruett
South Carolina
I used a pick with a hook on the end to raise the tabs instead of a screw driver
D
dcsang
I appreciate the guidance and responses. Between the weather and work hours I didn't have a chance to revisit this until today, and it was raining steadily. After removing the driver's side mirror I encountered the following.
1 - detached the heated mirror connections, activated the rear defroster, and checked voltage on the GN-VT and BK wires indicated below. The reading was 3v, which is likely the cause of failure. I couldn't check the RH mirror for reference at the time but I would expect 12v since it's working correctly. I expected either 12v or 0v, so pondering causes of the low reading.
2A & 2B - The auto dimming wires were broken at the connector. This is puzzling since the connection was severed at the very end of the pins, seemingly just below the surface of the connector. It doesn't seem logical that someone would cut these wires rather than simply unplugging the connector if there was an issue with this circuit. I removed the pins from the connector, recrimped and soldered the wires, and restored the connector.​
I will have to trace the heated mirror wire to locate the failure, weather permitting. There is continuity at the connection points on the back of the mirror.
Any suggestions on reliably triggering the auto-dimming circuit and the voltage reading I should expect on the that line? The marking just below the brown connector indicates '1.4V MAX' but would like to verify considering my unfamiliarity with this circuit.
D
dcsang
Just a quick update. I tested the dimming circuit by shining variable light at the rear view mirror sensor while checking voltage on the white supply connector (exhibit 2A above). The voltage reading ranged from 0v-1.35v based on the light intensity, which falls below the 1.4v MAX indicated on the back of the mirror.
I also retested the heated mirror supply wires and got 12v (13.4v exactly but 12v will be referenced as proper voltage in this case). I manipulated the wires while testing to check for intermittent connection but voltage remained constant. I am perplexed about yesterday's 3v reading.
Snapping that glass back in place was a bit of a challenge. I positioned the lower clips first with the intention of securing the top clips last since the mirror tilts downward to provide some visibility and access but it took 3 attempts to finally get it in place. It felt secure at times but the visual inspection revealed that the top clips were not properly secured, so be diligent if you run into this.
A short test drive confirmed that the dimming is now working, but no joy with the heated mirrors. I once again removed the glass and confirmed 12v on the heated mirror circuit with the rear defroster activated. I also tested 10.5 ohms resistance between the heated mirror leads on the back of the mirror and successfully used a 12v power supply to verify functionality. The connection remains the logical culprit so I'll clean the female spade connectors with electrical contact cleaner and sand the leads next. It's still raining here and snow is expected tomorrow so timing is uncertain.
star-art
Pacific Northwest
I know how much work it is taking mirrors apart. Not fun!
I was thinking you might have a broken trace in the heating element, causing an open circuit. But it looks like you verified continuity so it seems your element is good. You might use an ammeter connected in series though to make sure it's drawing current.
When I had my Grand Marquis mirrors apart I noticed the heating element is just a foil layer on the back side of the glass. The connections were very tight but the metal tabs connecting the electrical plug to the foil trace weren't secured that strongly. Just unplugging the connector caused a great deal of strain and I could see the tabs trying to lift off the glass. It looked like they could be damaged quite easily.
D
dcsang
I needed the vehicle so there was no time for extensive testing. However, this is what I observed today.
The voltage on the heated mirror supply line measured +1.5v with the defroster on and the door open. The voltage reversed to -12v when the defroster was turned off with the door open. The voltage is +12v with the door closed and the defroster on. I recall getting the initial 3v measurement with the door open but not sure why the door position affects this. The connections were cleaned but the mirror is still not heating. Perhaps checking amp draw should be the next step but I plan to remove the working passenger mirror and connect it to the driver's side for a definitive test.
Can anyone shed light of the voltage readings observed based on the door position?
Perhaps I got lucky, but the mirror snapped on in one shot this time.
star-art
Pacific Northwest
Wow, that is weird! Sounds like you have an intermittent wire problem, perhaps a short somewhere or a loose/damaged pin.
From the FSM, Rear View Mirrors section, Pinpoint Test F, disconnect the connector (C516 left, CC622 Right) and turn the ignition ON. Turn on Rear Defog. Check voltage at Pin 8 (brown/white). If less than 10V, check BCM fuse 59 (15A). If that fuse is OK, there is a problem in the wiring between the fuse and the door mirror.
With the ignition OFF, the resistance between Pin 2 (Black/Violet) (body side of the harness) and ground should be less than 5 ohms. This verifies a proper connection to ground.
Check the "jumper harness" (I'm guessing this means the wires between C516 and the connections on the back of the mirror glass) for open circuits, loose or damaged pins. If no wiring faults can be found, replace the mirror glass.
That's about it as far as the factory manual is concerned. . .
EDIT: If there's a short, you should get a reading of a few volts or less. If you get a reading of -12V, the probes on the voltmeter are likely backwards. I can think of no way you could get a negative voltage coming out of the fuse when the other mirror is working correctly and both are being fed by the same circuit. Of course, be sure you have a good clean ground point to connect the negative probe.
It sounds to me like there's a pinch/short in the wiring that occurs when the door is opened. Or, maybe a loose or damaged pin in one of the connectors.
D
dcsang
Thank you for that info! I firmly tugged on the harness boot at the door hinge while taking the open door measurements but there was no voltage variance. That doesn't necessarily rule out a loose or bad pin as you mentioned so now I have to access the inner door panel for C516. Hopefully I get at least one decent day in the coming weekends to do this, but swapping the mirrors should be fairly quick test. I would like to check the dimming circuit on the passenger mirror anyway since I can't detect if it's working as it should. There is noticeable dimming on the repaired driver's side now when triggered.
D
dcsang
There is no dimming circuit on the passenger mirror. It's driver-side only! :)
Thanks for setting that straight! I would have felt a bit silly after pulling that mirror. Hopefully I can get some testing in this weekend.
D
dcsang
I've isolated the problem to the wiring harness inside the mirror. There appears to be a common ground for the puddle light, heated mirror, and indicator light that joins somewhere in the harness and connects to chassis ground pin 2 on C516. I am getting intermittent continuity between those three grounds and the female connector to C516.
There is an inch or so of the harness visible before it disappears downward into the mirror housing and I can't pull it back to perform a proper inspection. An alternative is to jump a wire between the three grounds and splice into the ground wire on the female connector but it is darn near impossible to snake anything through the path of the wiring harness due to the narrow opening and winding bend.
Is there a way to disassemble the side mirror housing? I took a few pics but none really add value to this post.
star-art
Pacific Northwest
D
dcsang
I appreciate the continued support! That's a helpful link and the mirror motor removal should be quite similar. Unfortunately, my wiring harness snakes down into the joint where the mirror folds inward. I'll take some pics next time it's removed but hopefully the problem will be resolved by then.
One observation omitted from my previous post was that the ground wire for the heated mirror appears to be 18awg while the indicator bulb and puddle lights both appear to be 16awg. This was unexpected since they all tie into a single 18awg ground at the end of the harness. That seems undersized to me, but I suppose the engineers know best.
Happy Holidays to the forum!
D
dcsang
SUCCESS!!! :happy107:
The issue was a broken ground wire at the splice. Here are a few pics to hopefully aide others with related issues. Thank you star-art for the feedback and link to the F-150 mirror disassembly, which helped more than I initially anticipated.
Detach mirror from the assembly and removed screws 1-3 to dismount the mirror motor and screw 4 to remove the turn signal.
Disconnect the 2-pin electrical connection from the indicator light and disengage the plastic housing from the main body at the hinge. Very little pressure will be required.
Maneuver the wiring and mirror motor through the opening to separate.
This hinge nut can also be removed to separate the arm from the assembly, providing better access, but after reading that F-150 post I decided not to venture that route.
D
dcsang
We're still in better shape to access the wiring harness.
After removing the foam insulation from the mounting side of the mirror assembly you will see a plastic push-clip securing the wiring harness to the frame. Detach that clip by prying it to produce slack on the wiring. This will allow pulling about 1.5" of the wiring harness to the opposite side for proper inspection.
Peeling back the harness wrap exposed the culprit.
star-art
Pacific Northwest
Glad I could help!! :) If you'd gone to Ford with this problem they would've had you replace the entire mirror at significant cost. Glad you were able to fix it yourself!
Thanks for posting those pics and the detailed disassembly info. This will help me when I eventually upgrade to power folding/auto-dim/BLIS mirrors in the not-too-distant future. I *might* just be tempted to take them apart and add forward-facing turn signals like I did for my car a couple years ago.
D
dcsang
The factory used a copper clamp to join the ground wires for the puddle light, indicator light, and heated mirror to a single 18awg wire connecting to pin 2 of C516.
I avoided shortening the ground connection by stripping a bit of insulation and soldering the wire directly to the clamp. The original insulation was pushed back towards to wiring harness for reuse and heat shrink was added to the other side of the connection.
Insulate the connection.
Wrap the harness and pull back towards the mounting side of the mirror assembly, just enough to reattach the plastic clip removed in previous steps.
Reassemble in reverse order. The mirror is working like a champ!
Lessons were learned that were not fully discussed here, such as voltage drop. That might be a topic of it's own.
Thanks to everyone who contributed to this successful outcome!
D
dcsang
I hope I can be of assistance if necessary my friend! :)
