2003 EB stalling, 2wd, 5.4 - nightmare
ray young
wisconsin
i had a occasional buzzing in my SJB. when i swapped mine out for a updated one it cured a bunch of problems. it only took about 30 minutes to change.
RichardH
RichardH
TX
Good to know. (I think it's only a couple of bolts and several connectors of course)
iI you don't mind elaborating, what other problems were cured?
ray young
wisconsin
ok where to start.... power door locks stopped working. power windows stopped working. drivers rear turn signal stopped working. a no crank no start problem and it died because of the fuel pump relay going bad
RichardH
RichardH
TX
Thanks for sharing.
I think I need to update the SJB.
I have an odd issue with my locks. I lock the door - running, or not running and it unlocks itself. Only way to lock the truck is with fob.
I also need to fix the non-functional side mirror switch. I guess it could be part of the SJB.
ray young
wisconsin
i know very little about the SJB the main thing to remember is wherever you buy it from needs to have your Expy's VIN# to double check which SBJ you need
