What coolfeature have you discovered recently?
armoredsaint
mine is the hidden start under the cup holders if your batteries go **** up, yes I haven’t even read the manual ;)
Soliyou
OK
To adjust the rear A/C temperature, just press on “rear” button and it opens the rear A/C menu in the screen, even when in Apple CarPlay.
I was under the impression that this is an on/off button!
Deadman
How to shut the dumb lane keep back to OFF after you accidentally turn that babysitter feature on when trying to deactivate traction control to power slide thru the snow!
Jace
Utah
hidden start?
Yeah under one of the cup rubber inserts (by the shifter) there is a place to drop your keyfob that will allow you to start the vehicle if the keyfob's batteries die.
armoredsaint
armoredsaint
i wish mine had the front camera washers like they do in the Raptors, I know there's the rear washers for camera
st381183
New Mexico
When in compass mode on driver’s cluster, the turn by turn instructions will be displayed between the speedo and tach when you are using the nav system. Not as great as the map showing up there but pretty cool nonetheless.
mharwardt
Bakersfield, Ca
We found out the hard way about the key fob reset under the cup holder. We have a 2019 Expedition and 2017 F250. Expedition was at Rite Aid, door wouldn't unlock, finally did, then wouldn't start, said key not detected. Called husband, he came with F250. Finally got Expedition started and then F250 wouldn't start, same thing, key not detected, couldn't get it started, called AAA. While waiting googled it and saw that you could reset key fob by placing it in certain cupholder (after taking out top part of cupholder). Did that and it started right up. Neither battery was dead, something at that Rite Aid was interfering with signal. Employee at Rite Aid said we weren't first to tell him that their vehicle did that in their parking lot. We never park at the front of the store now, park on side, hasn't happened again. Weird.
armoredsaint
armoredsaint
I had that issue at a Home Depot with my BMW, doors wouldn’t lock or unlock and start about 1/2 the time and my radio station would get heavy static.
Deadman
Another reason I want my "KEY" back......
dlcorbett
Air Force
tx
Take this one up further, if your using the nav and turn the screen off, the directions will show up on top of the main screen while still being blacked out.
Wayne Decker
New York State
This is exactly why I go to CVS.
StealthyBulldog
Manitoba Canada
Deadman
