You realize that picture is from a MAX, correct? The shorty is 18 inches at maximum.Hi. Asking about the standard. Not Max
That photo is a regular - not Max.You realize that picture is from a MAX, correct? The shorty is 18 inches at maximum.
Given the slope of the 3rd row seats, your depth is 11.5", width is 51"
I stand corrected. I had gone out and looked at mine and clearly should have turned on the light.That photo is a regular - not Max.
Given the dimensions you don't have a prayer fitting 2 behind the third row.
And the door is very sensitive if there’s are slight binding and it’ll open back up
It is 30” high. Will it fit ? It is the Gunner Kennel (intermediated size)What's the height of the crates? The top edge of the gate slope down. So the width needs to be measured between the two lowest point at the top unless you want to disassemble the crates every time you load and unload them. I keep a 30.5"(H), 42"(L), 28"(W) crate in my 2018 Expidition short for our GSD almost always. The crate can't sit all the way to either side due to the lower height at the sides. There is only about 1 inch gap at the tallest section. I was hoping to get the 33" H crate for my GSD but it just wouldn't fit. The depth is not an issue. I only need to slide the 2nd row seats forward a little, which still leaves more leg room than my previous Buick Enclave
Sent from my SM-G930V using Tapatalk
