Prospective owner with a question on cargo
inverted
Delaware
With the third row up, can anyone tell me max depth (yellow line) and width (red line) in inches please ?
Need to fit two dog crates side by side. They are 23” wide and 34” long
thanks
Johhn14
boston
You realize that picture is from a MAX, correct? The shorty is 18 inches at maximum.
That photo is a regular - not Max.
Given the dimensions you don't have a prayer fitting 2 behind the third row.
Artie
Georgia
I stand corrected. I had gone out and looked at mine and clearly should have turned on the light.
armoredsaint
And the door is very sensitive if there’s are slight binding and it’ll open back up
zoey2015
US
What's the height of the crates? The top edge of the gate slope down. So the width needs to be measured between the two lowest point at the top unless you want to disassemble the crates every time you load and unload them. I keep a 30.5"(H), 42"(L), 28"(W) crate in my 2018 Expidition short for our GSD almost always. The crate can't sit all the way to either side due to the lower height at the sides. There is only about 1 inch gap at the tallest section. I was hoping to get the 33" H crate for my GSD but it just wouldn't fit. The depth is not an issue. I only need to slide the 2nd row seats forward a little, which still leaves more leg room than my previous Buick Enclave
Sent from my SM-G930V using Tapatalk
I
inverted
Delaware
It is 30” high. Will it fit ? It is the Gunner Kennel (intermediated size)
zoey2015
US
That's the same height as mine but 4" narrower. I'll measure it for you tomorrow to see if it will fit 2 crates
zoey2015
US
With 30" height, the useable floor width is only 38". You lose 6" on either side to to the slope down. I don't think you will be able to fit two crates side by side07972d6288a57098b8d8752677eb8897.jpg8f2778725fed3eb76a912337031e7421.jpg
Modelcarguy
Algoma
Sorry but not going to fit. Guess you gotta get smaller dogs! Just kidding, but with the third row up the cargo space gets really tiny really fast. Almost an either or scenario. With 7 or 8 folks in the car your not going to get much more than a hand bag in the back for each.
