@duneslider I will definitely be getting some of those. They sound like a great quick solution! The icons are spendy but they are not only height adjustable but also shock dampening so all it would take is a twist of the dial when loading up. Considering they were designed for the Expedition I'm guessing it will be an upgrade in ride out of the box. They are also rebuild-able so if its really bad I can always get them re-valved locally. My biggest concern is getting the truck to ignore the shocks when they are missing. Either by some sort of signal replicators or tricking the truck to think it doesn't have the CCD.
@Lou Hamilton Its most likely a combination of both. The difference in capacity is 600lbs. I cant even count how many times Raptor owners would ***** about why they could only tow 2-4k less than standard F150s. There is a reason why F350s ride like poop unloaded.
@dlcorbett Truck is on order so it will be a 2020. That is good to know that there are non ccd genuine Lincoln options available. Hopefully that means I can tell the truck to not look for the shocks.
