Never had an issue getting 2 turns out of them..
Most of the ones I deal with are Factory original rotors and many have never been turned but they are often on their second or third set of pads.
You might be able to turn them the first time you replace pads but rarely can you do it the second time. Now maybe you replace your pads you're right pads before they are fully used.
I never replace a brake pad until it hits the chirper or until it's down to those same similar end of life thicknesses.
That would make a world of difference. If you believe these garages and stuff and what they tell you when they rotate your tires they will tell you you're down to 20 or 30% and need new brake pads when you're actually at 70.
If you replace your brake pads after 35 to 50,000 miles and they were capable of going 75 to 85 or more then the rotor erosion is going to be so little that you probably can turn them.
But when you use the entire life of the pad and get 65 to 80 thousand miles out of the set it's highly unlikely they will be enough rotor thickness to turn them. Definitely not on the second set of pads.
I rarely purchase a vehicle with under a hundred thousand miles.
I did just buy two vehicles in the past year, one with 49k and the other with 84k but that is a real rarity for me and I just happened to find some really low mileage old ones.
The vehicles I buy are usually at least on their first replacement set of brake pads and sometimes rotors.
There's really little reason to worry about them. When the pads wear thin you will hit a wear indicator and hear them chirping or you will feel them grinding or often if you pay attention you can feel a difference when the pad material starts to get thin and know you better inspect them, or you can look in through the wheel and around back with a bright flashlight and usually tell without having to remove the wheel or if the rotors get warped you'll feel a pulsation or surging in the pedal.... so really it makes little difference. The car is going to stop just fine. When there is a problem and needs attention, it will let you know.
As I said earlier, these types of issues even warp rotors and such don't really reduce your braking ability or make the car less safe. But what does, and what most people overlook and fail to even inspect, are the brake lines and the things that over the years will get rusty and dangerous and right on the verge of popping a pinhole and squirting brake fluid everywhere and losing pedal pressure and a great deal of your stopping ability.
Even with high quality, high performance rotors calipers brake pads and the slider pins and everything in perfect working order make little difference when you happen to have to stop very hard one day and you popping crusty spot on a brake line and your pedal sinks down to the floor and gets mushy.
