Breaker
Does anyone have a working spreadsheet for the 2019 Expy?
does anyone know if these codes work for the '20 too?
So far Coolant and trans temperature over gauges,and disable fake engine noise has worked.
IPC 720-07-01 xxxx xE5x xxxx
ACM 727-01-01 xxxx x0xx ***
Stock value for heated/cooled seats with HSW isn't what I expected, or documented as a normal value in spread sheets - so I have not changed that. Next time around I'll be looking at doing 3 ding at start up, panic alarm set to two pressens, and bambi mode.
Which code is which?
does anyone have the code for Bambi Mode?
yeah I tried that one ....and it didn't turn Bambi on (that sounds weird as I type it.
my 2020 was set to 0001 1401 026D and I changed it to 0001 1400 026D w/ no results.
Im not having any luck w/ the double horn honk when key not present either.
What setting did you use? I know you have the 2020, but I used the following on my 2019 with success:
BCM 726-41-02 xxx0 xxxx xxxx
My default stock setting was 0001 0101 0174.
Good evening folks. I'm new here but I've been doing a lot of research before trying this out myself. I've gotten my ODB2 connector (Veepeak brand), purchased a Forscan license, and started playing with the plain English/easy mods on my 2020 Max XLT. For some reason, I'm connecting up fine and everything looks to be working, writing changes shows to work in Forscan, but only one (heated/cooled seat buttons on home screen) has actually worked. They just don't seem to take. I'm following all the steps as explained in all the forums and videos. Another odd thing is within some of the modules I show some things as "disabled" that I know are working (like remote start). I'm to the point of thinking any updates will have to be done through the As-Built codes, and that we'll have to wait until a new spreadsheet comes out that is applicable to newer Expeds. As some others have mentioned, the codes in the F150 spreadsheet don't line up with what I'm showing for the 20 Exped. Does anyone know how the Forscan group works well enough to know if they are working on this currently? I'm wondering if it should be pushed with Forscan support or if they're on it. Thoughts?
