2019 Expy Forscan
taaangy234
US
So far I tried last night, only had these working so far.
BdyCM 726-41-02 xxx0 xxxx xxxx Disable No Key Present Double Honk
BdyCM 726-27-01 xxxx xxx0 xxxx Enable Fogs On w/ LED headlamps
APIM 7D0-01-01 xxxx xxxx xExx Enable On-Screen H/C Seat Buttons
APIM 7D0-01-01 9xxx xxxx xxxx Disable Sirius As Audio Source
APIM 7D0-02-01 5753 xxxx xxxx Data Entry While Vehicle Moving
As I used a OBDII Bluetooth + W10 virtual machine running on my work laptop.
-I can't do any SCCM mods without getting the wired one.
I tried the these as well but it threw a bunch of warning on my ODO with sensors, etc...
Lights - DRL options BCM 726-11-01 x?xx xxxx xx Change ? To: 0-DRL Disable, 1-DRL 50% Low Beam, 2-DRL Fog Lights, 3-DRL Turn Signal
Auto Start/Stop give battery error "Charging System Service Now"
ssmorga
Alabama
I just got the wife a 2019 Expy XLT and somehow she has managed to turn off the Auto Start/Stop in the menu without the need for using ForScan to turn it off. Do y'all not have this option in the menu? She went into the Vehicle Settings menu in the Information Screen/Cluster, then went to Advanced Settings, then selected Auto Engine Off and disabled it. Haven't had an issue with the Auto Start/Stop kicking on since then ...... have yall tried that to get the Start/Stop to shut off?
retired_chemist
NH
My experience says that only works until you shut off the vehicle. It then reverts to the factory default. I find it easier to turn off the auto start/stop with the button on the dash.
Tracy Cook
CO
does anyone know if these codes work for the '20 too?
I've started updating mine. Some codes have worked, some I have not tried yet - when looking at the default values and some of the google spread sheets put out by others, some default values don't line up. so have been hesitant to change too many things.
So far Coolant and trans temperature over gauges,and disable fake engine noise has worked.
IPC 720-07-01 xxxx xE5x xxxx
ACM 727-01-01 xxxx x0xx ***
Stock value for heated/cooled seats with HSW isn't what I expected, or documented as a normal value in spread sheets - so I have not changed that. Next time around I'll be looking at doing 3 ding at start up, panic alarm set to two pressens, and bambi mode.
I'm referencing - https://docs.google.com/spreadsheets/d/1qf2gYgkhmsX-dnFO3Ki0nYUvr7aeLKsHsA0WxhDns1s/edit#gid=0
https://docs.google.com/spreadsheet...iVSlDFGFHnfeuhb3RTMVz95730/edit#gid=815852466
https://docs.google.com/spreadsheet...TKARDo2Y7lfSOMFj6Gott8g7yg/edit#gid=756156726
bushpilot
Houston, Tx
Which code is which?
on my '17 super duty -
I disabled:
Double horn honk (occurs when you exit running truck w/ key in pocket).
Drivers seatbelt warning (left all other seat belt warnings on)
I ENABLED:
Numbers over Gauges
Bambi mode (driving/fog lights on w/ high beams)
Remove Sirus Option from infotainment (the day the free trial ran out)
Lower TPMS pressure (i run 55psi, factory minimum was 65psi)
Heated & Cooled Seat Icons on Home Screen (infotainment system / center of dash).
Increased power point time out after engine off (was 15min) to 4 hours (can make them hot all the time)
Turn signal flash increase to 5 flashes (quick lane change/short press of turn signal) - was 3 flashes
These items aren't necessary on the Expy but I also enabled:
Heated Steering Wheel control on Home Screen
Global Window Close (can close windows w/ remote/fob)
Add DPF filter % full (gauge)
Tracy Cook
CO
Did some more playing this weekend on my 2020 Maxpedition Plat - I can confirm the following codes work
ACM 727-01-01 xxxx x0xx xxxx - Fake engine noise off - V8 sound disabled
APIM 7D0-01-01 xxxx xxxx xExx - heated/Cooled seats, HSW, Rear Controls on Sync Screen
APIM 7D0-02-01 xxxx x5xx xxxx - Raptor boot up screen
APIM 7D0-02-01 x7xx xxxx xxxx - Can enter nav while driving - Will set European speed limit sign in Nav, and disables 911 call on crash - so I've set it back to the default value of 5
IPC 720-07-01 xxxx xE5x xxxx - Engine-trans temps over gauges
HSWM 714-01-01 Cxxx xxxx xxxx - Heated Steering Wheel timeout - 18min
SCCM 724-01-01 xxxx xBxx xx - 5 turn signal flash
I'm trying to write BCM values - but on my Expy writing get's to about 4% and then gives me an error - anyone else see this behavior - this is the message that it gives.
service procedure has been interrupted
M Bennett
