Update all versions of Ford Sync 3 to the latest Sync 3.4
Moderator
I updated my post, but still I believe you are correct. I find the screen quality on the 6 plus to be decent for my needs and the battery life is still sitting at 87%. People make choices everyday about things they want and/or need. But that being said if anyone feels bad for me and wants to send an iPhone 11 Pro my way...go right ahead lmao.
My issue was not with the decision to stay with the older phone, but the expectation that it’s performance would not degrade. It is simply an unrealistic expectation that a 6 year old tech device would not see a performance hit running current software. The software trends with the hard ware. Complexity and features increase, which in turn requires more/faster hardware. That is simply how it works.
I am a tech by trade, so I typically get the newest every year. I actually kept my Xs Max this year and did not upgrade to the 11 Pro, because I have been very happy with it. But to expect it to keep up with the newest, Nope.
Gumby
Beaumont, Alberta
Let's not get too confused over a post. I was not crying about degradation of performance. I am fully aware a 6 yr old phone (or pretty much any tech for that matter) will be affected by age / use / wear and tear / etc. I know what I have in my 6 Plus and I'm fine with it. NBD. Maybe there was a misunderstanding on my comments somewhere possibly due to the crisper / snappy correlation to my 6 plus comment.
Let's get this topic back on track lol.
Moderator
Yeah...I'm "only" on a 6 plus. The screen is still great (large size) but I find the performance is degrading (slower). Thanks Apple.
You said the above. No confusion. And the “Thanks Apple” clearly implies it was their fault a 6 year old device was getting slower.
Sorry, but call it as I see it.
Agreed. Back on Topic.
Wally
US
Worked like a charm...only two minor complaints are No Calm (don’t really care) and the background for night doesn’t change all the colors. Bottom and top banners remain the same color blue.
Thanks Loki for all the help and feedback
Moderator
No problem. Only way to get Calm Mode, is to do the firmware update, and it is a PAIN! Certain revisions of the APIM shouldn’t even attempt the firmware.
bushpilot
Houston, Tx
Yes, but since I have the Black Stealth interior, I like the more black-like theme.
Thanks for looking out, though. :)
its another one for my wish list too! I have set the screen for "night" mode to minimize the brightness.
my 2017 Platinum F350 had many more color/background options (including black / w/out any gradient top or bottom)...of course the truck also had DIMMABLE ambient lighting colors that I could set ...illuminating the door pockets, handles, cup holder/console and floorboards (miss that too)!
Rufus4bz
Illinois
I've looked and have not been able to verify but if I update to 3.4 on my '19 Platinum, will I need to redo all the changes I did with forscan (bambi mode etc)?
Moderator
No. All of mine stuck. Only thing that you have to set back up is BT pairing and CarPlay/AA.
carymccarr
Earth
Curious if anyone has a screenshot of the black label vs regular navigator screen? Is there supposed to be a BL splash graphic or anything?
Odd sync STILL doesn’t merge all of your favorite/preset stations into a single list regardless of source and that you can’t scroll through the entire list from the steering wheel controls.
Moderator
3.4 Allows you to put Sat and FM stations on the same page. Mine will also go to the 2nd page if I am at the end of the 1st.
Startup Image and Theme are 2 different settings. They are in different locations via programming.
carymccarr
Earth
That would be great! I just checked and I’m on version 3.4 and cant scroll to the next set of presets/favorites with steering wheel controls...when it gets to the end of the first 6 presets it goes back to the first one instead of moving to the next 6...
nor can I combine fm/xm stations. How are you performing those tasks?
Are you saying you need to program startup in forscan? Is there a specific black label startup? What does it say?
Thanks for all the info. Very helpful.
Moderator
Let me Double Check I can do that in the Expy. I definitely could do it in my Edge. I know I can do it in my 2020 Explorer ST, cause I set the presets yesterday. It is running 3.4.
Moderator
I haven’t looked at all the StartUp Logos, but Themes and Start Up Logos are separate FORSCAN settings.
carymccarr
Earth
That would be nuts if you can do it on all of those ford vehicles but for some reason it’s locked out on the expy/Navi.
Thanks for checking.
Moderator
Definitely cannot put Sat and FM on the same page in my 17 Expy with 3.4 20021.
My 16 Edge Sport with 3.4 20021 Could. My 2020 Explorer ST can. Must be an APIM firmware version thing!
carymccarr
Earth
Why on earth would ford hobble BASIC functionality on its highest end vehicles lol?!
