Update all versions of Ford Sync 3 to the latest Sync 3.4
carymccarr
Earth
Curious if anyone has a screenshot of the black label vs regular navigator screen? Is there supposed to be a BL splash graphic or anything?
Odd sync STILL doesn’t merge all of your favorite/preset stations into a single list regardless of source and that you can’t scroll through the entire list from the steering wheel controls.
Super Moderator
Super Moderator
3.4 Allows you to put Sat and FM stations on the same page. Mine will also go to the 2nd page if I am at the end of the 1st.
Startup Image and Theme are 2 different settings. They are in different locations via programming.
carymccarr
Earth
That would be great! I just checked and I’m on version 3.4 and cant scroll to the next set of presets/favorites with steering wheel controls...when it gets to the end of the first 6 presets it goes back to the first one instead of moving to the next 6...
nor can I combine fm/xm stations. How are you performing those tasks?
Are you saying you need to program startup in forscan? Is there a specific black label startup? What does it say?
Thanks for all the info. Very helpful.
Super Moderator
Super Moderator
Let me Double Check I can do that in the Expy. I definitely could do it in my Edge. I know I can do it in my 2020 Explorer ST, cause I set the presets yesterday. It is running 3.4.
Super Moderator
Super Moderator
I haven’t looked at all the StartUp Logos, but Themes and Start Up Logos are separate FORSCAN settings.
carymccarr
Earth
That would be nuts if you can do it on all of those ford vehicles but for some reason it’s locked out on the expy/Navi.
Thanks for checking.
Super Moderator
Super Moderator
Definitely cannot put Sat and FM on the same page in my 17 Expy with 3.4 20021.
My 16 Edge Sport with 3.4 20021 Could. My 2020 Explorer ST can. Must be an APIM firmware version thing!
carymccarr
Earth
Why on earth would ford hobble BASIC functionality on its highest end vehicles lol?!
