I did the idle relearn process using this site and it didn't help. I actually disconnected the battery and tried it again and there is still rough idle and hesitation. When I get to 50mph. there is a really rough shake for a few mph after 50 then goes away and will come back after letting off the throttle and reapplying the throttle.
There's a few things that I maybe helped contribute to the problem:
1. the battery cables had a lot of acid buildup, so I cleaned them and dumped water over the area to wash off the cleaner. Maybe a connector got wet? I sprayed some wd40 on a few connectors last night,
2. Placing the new battery on thee tray, I sat it on something and pulled it out (okay yanked it out). I didn't notice what it was but the only thing that is loose around there was the vacuum hose that goes to (that thing on top of the three way split coolant hose that goes to the firewall)________?
Sound familiar to anyone at all?
