Hard steering only when Towing
Joe m
Hello all, I have a new to me 2009 limited 2 wheel drive and the steering seems hard when Towing. Even when stopped at a light and turning the wheel it's hard to do... Sometimes.... When I don't have a load on (travel trailer) all seems fine.
I checked steering fluid and it's at a normal range.
Any thoughts???
Thanks
Retiredusps
N.J.
the expeditions as well as the f150 are prone to have the universal on the lower end of steering shaft freeze up. wife expy would be ok one day and the next be stiff.you can try aspray lube and soak the xzyk out of it but will reaper after awhile. only real fix is to replace the whole shaft. no one sells just the ujoint
Anchorclanker
Statesville, NC
I'm no expert but just a thought. If you're using a wdh could it be set up wrong? Throwing too much weight forward? I have an 08 LTD and tow a camper and have never had this problem. FWIW.
Sent from my Pixel 3 using Tapatalk
J
Joe m
Great thought....
If it's what first responder thinks... It will happen sometime without Towing.. if it does not happen again until I start Towing then it could be my WDH.
J
Joe m
The top and bottom are one unit.. Right? I've been checking out shafts but getting confused.. So much out there.
07navi
Mt.Shasta California
Yes, just one bolt at the bottom and it slides out after unbolting the top, not that hard and not expensive.
Adieu
SoCal
Is it drawing power? Maybe your alternator isn't dealing too well with keeping the juice flowing at idle
joethefordguy
I have to agree. If this only happens when towing, then the tow config must be looked at; either the wdh or the load balance itself.
J
Joe m
I really have only driven it a couple of times in the past month.. Lockdown...
So I can't say it's only when Towing... But I'll start driving it more and see. Thanks
