1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Hard steering only when Towing
Discussion in '3rd Gen - 2007 - 2017' started by Joe m, May 23, 2020 at 3:36 PM.
  1. Joe m
    Joe m Member
    51
    16
    Feb 3, 2020
    48183
    Hello all, I have a new to me 2009 limited 2 wheel drive and the steering seems hard when Towing. Even when stopped at a light and turning the wheel it's hard to do... Sometimes.... When I don't have a load on (travel trailer) all seems fine.
    I checked steering fluid and it's at a normal range.
    Any thoughts???
    Thanks
  2. Retiredusps
    Retiredusps Full Access Members
    71
    53
    26
    Oct 28, 2018
    N.J.
    the expeditions as well as the f150 are prone to have the universal on the lower end of steering shaft freeze up. wife expy would be ok one day and the next be stiff.you can try aspray lube and soak the xzyk out of it but will reaper after awhile. only real fix is to replace the whole shaft. no one sells just the ujoint
    Joe m likes this.
  3. Anchorclanker
    Anchorclanker Well-Known Member
    64
    45
    17
    Jan 27, 2018
    Statesville, NC
    I'm no expert but just a thought. If you're using a wdh could it be set up wrong? Throwing too much weight forward? I have an 08 LTD and tow a camper and have never had this problem. FWIW.
    Sent from my Pixel 3 using Tapatalk
    Joe m likes this.
  4. Joe m
    Joe m Member
    51
    16
    Feb 3, 2020
    48183
    Great thought....
    If it's what first responder thinks... It will happen sometime without Towing.. if it does not happen again until I start Towing then it could be my WDH.
  5. 07navi
    07navi Full Access Members
    76
    881
    192
    Feb 3, 2020
    Mt.Shasta California
    The top u-joint in the steering shaft freezes too but a new shaft if cheap on ebay and is a pretty easy fix.
    Joe m likes this.
  6. Joe m
    Joe m Member
    51
    16
    Feb 3, 2020
    48183
    The top and bottom are one unit.. Right? I've been checking out shafts but getting confused.. So much out there.
  7. 07navi
    76
    881
    192
    Feb 3, 2020
    Yes, just one bolt at the bottom and it slides out after unbolting the top, not that hard and not expensive.
  8. Adieu
    Adieu Full Access Members
    34
    3,557
    726
    Dec 22, 2016
    SoCal
    Is it drawing power? Maybe your alternator isn't dealing too well with keeping the juice flowing at idle
  9. joethefordguy
    joethefordguy Full Access Members
    311
    78
    Apr 10, 2017
    I have to agree. If this only happens when towing, then the tow config must be looked at; either the wdh or the load balance itself.
  10. Joe m
    Joe m Member
    51
    16
    Feb 3, 2020
    48183
    I really have only driven it a couple of times in the past month.. Lockdown...
    So I can't say it's only when Towing... But I'll start driving it more and see. Thanks
Share This Page
