I read the EB turbos are 51mm(only 2") Installing a new air box for noise, is one of the dumbist things I heard of in a while. The factory airbox may have an air silencer, that can be removed.Even with an open lid box the turbos can’t make to much noise. They are so small compared to a diesel. You can vent the blow off to atmosphere. The Turbosmart plug and play makes a loud PHSsst sound for the same price as an intake. I had the S&B filter on my F-150. The fit and finish was great. No extra noise or power came from it though. The one posted above at least looks really cool.
Thts the only thing you’ll get is noise, unless you’re tunedI read the EB turbos are 51mm(only 2") Installing a new air box for noise, is one of the dumbist things I heard of in a while. The factory airbox may have an air silencer, that can be removed.
Light coat of oil and leave it in the sun to soak in. Touch up any 'light spots'. K&N filters work better a little dirty(sounds crazy). They recommend 50K before cleaning. Save the old filter to use while cleaning and oiling the K&N. Some believe this filter lets grit into engine. SCT tuners have a setting for K&N airfilters on the Mustang.Nope! I've been doing this to my cars since I was 16 and had a 2.0T VW. The only time I ruined a MAF sensor was after 38K miles I decided I'd re-oil the K&N air filter myself and installed it with too much oil on the filter.
Now I just buy a new K&N air filter every 25K miles or so and drop it in to avoid that issue. Wasteful? Probably, but the way I see it it's much cheaper than a cold air intake and worry-free compared to re-oiling. I'm at 12K miles on my Expy with the K&N installed since the 2nd day.
Guess I won't tell you how much I spent on the CF intake for my Audi... And I got a deal too... Times is changin.... I bet you spent less than $100 on an exhaust too. The good 'ol days... When V8s were simple and power gains were easy.
You can tune the 5.0l in the Mustang for the drop in K&N. Without a tune, the computer will just adjust fuel trim, to compensate for the additional airflow. I am getting about 18.6mpg in my 2011 Mustang. I was getting around 18.1 before. The wide open throttle response is incredible.But did it add any power? Drop some weight? No one has made any major HP gains over the Ford engineers. Unless you do more work to the motor to make it need more air. They all are pretty much eye candy. I personally love bling and would buy the one shown just because of the blue pipes or get the one that has the cool pipes and twin open filters for ultimate flash.
