AC not cold at idle
Ilka Wagner
Hearne TX
Good morning,
We have a 2018 Expy and live in Texas. So, the heat here is significant in the summer. I noticed that when the Expy is at idle, the temp of the air coming out of the AC vent is basically luke warm, certainly not anywhere near cold. Once I start moving, all is well and it blows cold as it should. This is regardless of whether I just started the vehicle and it has not warmed up yet of if I am driving for hours. As soon as we get to a light or stop, the temp become warm. Is this a common issue? Can't get anyone at our dealership in service to ever get back to me.
Thank you
Deadman
Thank your auto-stop BS If you have it still. Typically tho compressors run at lowest rpm at idle so once you speed up the compressor speeds up and air passes across the condenser, so that's how it works....
Ilka Wagner
Ilka Wagner
Hearne TX
So even if that is disabled when I start the vehicle? Ugh. I was hoping there was a fan defective at idle that was supposed to provide the air flow.
Has anyone added an auxiliary fan to solve this
osteodoc08
GA
Get your Freon level checked. A slightly low level can doo this too. Even in GA heat during the summer 95+ and 100% humidity, once the interior is cool it blows ice cold even at idle. The compressor stops when the auto stop activated. I turn it off as soon as I start the vehicle. It’s become second nature.
aggiegrad05
North Texas
If you are disabling the auto start when you get in the vehicle (or have it permanently disabled thru forscan or an autoeliminator) then it is NOT causing your problem.
The auto start system does shut off the compressor when it turns off the vehicle. But it will also turn the vehicle and the compressor back on if necessary.
But again, if you have disabled the system and your vehicle is not shutting down at a stop, then you have something else going on.
Soliyou
OK
Could be low on charge or defective fan or fan relay. I would lean towards fan issue if it gets cold When the car is moving.
You don’t need an auxiliary fan. That thing is sooo loud with the compressor on. You can easily check that fans are working at high speed when Compressor is on by listening or looking under the hood.
you can also use the meat thermometer and check vent temperature at idle, 2000 rpm, and when moving.
Ilka Wagner
Ilka Wagner
Hearne TX
Thanks for all of the replies everyone! Will take it to the dealer and have them assess. Glad for once some went askew while under warranty. Appreciate all of the input!
duneslider
Utah
Didn't some of the early 2018's have issues with contaminated coolant in the AC? Thought I had heard that and there is some special equipment that has to be used to evacuate it and put the new stuff in?
Ilka Wagner
Ilka Wagner
Hearne TX
I read something similar on another thread but thought it would be odd to just manifest itself at idle. Will ask dealership when I take it in.
Calidad
My Sequoia had a hard time cooling at idle also. It was two part, it was low on coolant but no leaks which was odd, and a fan housing had a broken mounting bracket causing the fan to lift away from the AC radiator both those fixed and it was cold again.
NyackRob79
Nyack, NY
I have an 2018. A/C got progressively “weaker” until it didn’t work at all. They had to replace the whole rear exchanger. Couple of grand worth of warranty work.
2018ExpyPlatinum
Arizona
I know I live in Arizona, but I don't think mine is very cold. I have the back set at 70, the front 70-72. I mean, I know the Expy is big, but my wife's RAV4 is set at 74-75 and it blows cold, and gets very comfy. If you use a meat thermo, what temp should be coming out, as a rule? I used to know that, but purged that info. I wonder if I have an issue? Thoughts?
Dice Roll
Craps Table
So far mine gets cold and stays cold at idle unless the auto stop kicks in. That’s only a few seconds so it doesn’t matter as it can easily catch right back up.
It doesn’t get instant cold out the vents like I like when hot out. Our Camry has noticeable change within ten seconds or so of starting up. It’s a 12. Same with other older vehicles I had.
The 16 odyssey was crappy at startup as well. Might be some epa business keeping hem from working as well these days.
FeO2
What Freon type is in the '18's and up now?
I vaguely remembered reading of a new type of refrigerant coming in newer vehicles....
Dice Roll
Craps Table
Y1234 was the new one I heard about a few years back. You might be right about it being the issue.
