Ordered an intercooler!
302Xplorer
Richmond, Virginia
Moderator
National Speed in Richmond is not the place to go for EcoBoosts. I know many EB owners, some slightly modded, some serious bolt ons, and none of them were even close to potential with a National Speed tune. They did ZERO to the Trans which is important.
I recommend Adam@ZFGRacing if you are getting serious about mods, which it sounds like you are.
302Xplorer
302Xplorer
Richmond, Virginia
I think I’ll notice a difference with everything else stock. It came with 1 screw. Doesn’t get much more “plug and play” than that. 3540fe4f32993529f941704dbc68e487.jpgf94ca5226406d7f1f1d51adf1fabfb97.jpgde51f7bf9393c7eca4277d4f55683c63.jpg2bf3bfee09c1ef22bbae53277da8e9b7.jpg
Artie
Georgia
I think I’ll notice a difference with everything else stock. It came with 1 screw. Doesn’t get much 3540fe4f32993529f941704dbc68e487.jpgf94ca5226406d7f1f1d51adf1fabfb97.jpgde51f7bf9393c7eca4277d4f55683c63.jpg2bf3bfee09c1ef22bbae53277da8e9b7.jpgmore “plug and play” than that.
Are you positive it will fit without any body modifications?
Very curious to here your before and after results.
AKentPhoto
New Orleans
Nice! You aren't wasting any time. Eager to hear your thoughts. I'm going to be doing a fair amount of towing in hot temps so I definitely want to do one as well. If you have any thoughts on why you chose the Garrett I'd be interested.
Soliyou
OK
Looks very nice. They indicate on their website that removal of grill shutters is necessary.
Moderator
I would love to get some before and after logging on the IAT's, and MCT's!
Fozzy
Riverton
Wasn’t part of the grill shutters to not cool the CAC so much? So you didn’t need to drill a weep hole in the CAC to let the condensation out? Will a bigger CAC add to this problem?
Soliyou
OK
This larger inter cooler actually has a drain plug :)
302Xplorer
302Xplorer
Richmond, Virginia
Awesome stuff!!
Guessing the 124 IAT2 was after a hard run?
Yes. My friend and I wanted to get some baseline # s before the install. 5.8 was the quickest 0-60 we had. It really dropped off after that. Might be what “heat soaked” is about. 5791616d332d6129a67081a294a36279.jpg
