CVFab Titan Intercooler and GoFastBits BOV install
gtr09
Midwest
I did these on mine last week and thought I'd share a few notes.
CVFab Titan Intercooler Link
Go Fast Bits 2013-2020 F150 & Raptor 3.5L & 2.7L EcoBoost GFB DV+ BOV T9464 Link
Install is straightforward using Youtube videos and following instructions, however, I didn't find any videos that showed these 2 together. While both are drop in by themselves, they don't quite fit together perfectly.
1) The BOV metal body has 2 slots on it that slide past 2 tabs on the intercooler upon insertion. The tabs slide past the slots and then you rotate the BOV to lock it into place. Unfortunately, the slots on the BOV are smaller than the tabs on the intercooler and it will not slide in. I just took a hand file and widened the slots on the BOV and thinned the tabs on the intercooler until it popped in. Easy enough but not plug and play.
2) The stock IC is plastic and the BOV bracket is attached with a wood screw. The Titan is metal so they send a machine screw with it. The issue is the GFB BOV bracket is thinner than the stock bracket which makes the machine screw too long and it will bottom out before the BOV is snug. A couple of washers solved the issue.
3) The intercooler is thicker so you have to cut off part of the square plastic shroud that houses the louvres. On F-150s the shroud is a two piece deal so you can just unsnap half of it. On the Expedition it's one piece. You could just cut at the halfway point, but I measured mine so as not to create a big gap between the intercooler and the shroud. Not sure if that matters but can't hurt right? I needed to cut 5/8" off of the sides and bottom of the shroud to get a close fit. I did not need to cut the top - it seemed to just lay on top of the intercooler without issue. To make (fairly) straight lines I used a multitool to cut and clamped some wooden shims I had laying around for a straight edge.
lefty hack
Vegas
Great pics and explanation. I've already purchased but not installed a Whipple intercooler. It looks to me that I can add this new BOV to my project. Is there anything that you are aware of that might prevent it from working with the Whipple?Thanks
G
gtr09
Midwest
Thank you, from looking at the Whipple I can't see any reason this BOV won't work - worst case you run into what I did.
Black
Kentucky
Thanks for the write up.
How did you come to choose the CVFab?? Just picked up a 22 Navigator for my wife and am trying to decide between the CVFab and Livernois
5280tunage
colorado
FWIW I used a Turbosmart Vee Port VTA BOV with a Mishimoto intercooler and it was plug and play, works great! Couple things I would say, is if you're in really dirty environments, make sure you once a quarter squirt a tiny bit of silicone spray or a good lubricant that dries non-stick in the piston. They can stick once a while since they are exposed.
