Can I add the power tip and slide
Riverside county
Wanted to get the push button tip and slide to make it easy for the littles to get in the car but is that only on the platinum version and is it possible to add it to the limited model?
wakeboarder
Fort Lauderdale, FL
You should have the pushbutton tip and slide with a limited. The pushbutton is on the pillar near the back of the second row seat.
I don’t have a platinum, but I don’t think there is a power function to the tip and slide. The power function is for the folding. It may also be for unfold, but I’m unsure. My second row has had 3 car seats in it since the day I bought it.
Deadman
The seatbelt disables this feature once you use the seatbelt as kids get over 40 lbs, so its short lived!
scottdm
Western PA
That's why we went with Captain's Chairs on ours so our oldest son can get to the 3rd row without having to move the 2nd row seats. Pros/Cons to both arrangements. Some days I wish we had the 2nd row bench when extra friends are along...
shane_th_ee
Seattle
It even came on my lowly XLT...
wakeboarder
Fort Lauderdale, FL
We had 3 within 17 months. So they are close to the same stages. I agree that over 40 lbs in a convertible seat the feature doesn’t work. I think with my 3, I can shift them around to always have one outer position not using the Expedition’s seatbelt. This would make the tip and slide usable.
Once you are in the booster stage, I don’t think it will matter much. Some booster seats allow you to hold the booster seat in place with the latch while the child is actually secured with the Expedition’s seatbelt.
N
Riverside county
I have seen the button can't remember how's it's used though. I know where it should be cause I can see the cut out was wondering if I just need the button and maybe a harness to connect it to the seat or if it requires a different actuator to tip the seat
GB19XLT
That is strange that you don’t have it. I have a limited and it has it
wakeboarder
Fort Lauderdale, FL
Mine has an electric actuator. I think it’s only function is to unlatch the back of the seat. It seams to do the same thing as the lever at the top of the seat.
I took a couple of videos, but I’m not sure what the best way to upload them from my phone.
wakeboarder
Fort Lauderdale, FL
I just looked at the wiring diagrams. The switch sends a signal to a Power Fold Module. The Power Fold Module controls the motor for the tip and slide latch. The feature is called Easy Entry in the wiring diagram.
