Largest GD Trailer 2020 Expy can safely tow long term?
Matthew Marlowe
San Diego
What I really want bad, but I'm guessing would get me in trouble bigtime:
View media item 7180
Alternatives that might work out and be safer and rated reasonably within limits, but are either smaller or have lower quality construction:
View media item 7181View media item 7182
Which would you choose if you would be stuck with it permanently? Alternatives like the Airstream 30 classic? GD transcend seem to have better construction than the imagine...
Explore 265bh seems to be the winner by default...
Tow vehicle: 2020 Expy Plat Max Tow, gen-y hd 10k torsion hitch...likely upgrade at trailer purchase to equalizer wdh w/ trailer sway...
JasonH
Houston, TX
The first two are too heavy and the last is pushing it. If you're traveling with family, they're all too heavy. You need to be closer to 7k loaded. It's very easy to go over. Upgraded mattresses, television, chairs, tables, utensils, tools, food, drinks... all of these things will add substantial weight. I suggest looking at lightweight or shorter models. Some of the cabinetry and finishings are nice, but they add weight. Most Expedition trims don't have a lot of payload to work with.
M
Matthew Marlowe
San Diego
Kids are going off to college soon, so should most of the time just be 2 people plus a dog. We have 2020 platinum max tow Expy. But, Kids will visit hopefully so occasionally might be 4 people plus two dogs. Not sure how frequently we will move the trailer. We are looking at moving into one while we move out of (escape) California and build a retirement house elsewhere plus travel country. Estimating living in it for 2-5yrs and would prefer not to feel too cramped. I could get a larger trailer and rent/lease super duty, but that seems overkill when we already have and want expy long term.
LovinPSDs
Houston
I think I would buy a 2500RL or 2600RB AND a Propride/Hensley hitch. That will eliminate 99% of the drama from a "sway" and control perspective. You'll be flirting with Max payload, especially with 4 adults in the rig but... you know...
Couch and dinette will sleep plenty of visitors.
Chip S
Dallas
I would like to pile on here. I've done a ton of research on hitch weight, GVWR, payload, etc. What I have discovered is that there are no consistent numbers and the only way to know what works is to look at the sticker on the trailer. Now, with that being said, the guidelines provided from the trailer manufacturer give you the amounts probably +/- 10%.
I too have a question about trailering. I am interested in a 2800BH. Here are the specs from the manufacturer:
UVW
6238 lbs
Hitch Weight
604 lbs
GVWR
7995 lbs
Length
32' 0"
Height
11' 1"
Here are the specs from my 2020 Exp Max (with HD towing package)
GVWR: 7400
GCVWR: 15,200
Payload: 1621
Towing: 9,000
If I factor in about 500lbs of passengers (2 adults, 3 kids) and about 300lbs of cargo (in the vehicle), I have about 200 lbs of payload remaining
I've been using this as my calculator when looking at rigs
Doesn't this seem like it works and still maintain enough cushion and margin for not being at the maximum for everything?
johnboneske
I saw this a fee weeks ago.. i saw a 2019 standard wheel base Expedition pulling a Outback 328RL which has a GVWR of 10500 and a dry weight of 8600. I asked the owner and he said it towed great, and was even good in the mountains. I think he was WAY over weight but it's his choice to make. My point is apparently the Expedition tows really good, so you should be fine. I posted the pic in another spot in here...
JasonH
Houston, TX
I don't endorse this. While the Expedition has plenty of power to handle heavy loads, the suspension and brakes will become a limitation. Leave enough margin for an emergency. Also, the vehicle has very little engine braking due to the small engine size. Better safe than sorry. Your family's life may depend on the decision you make.
I have only heard good things about ProPride and Hensley hitches, but they should not be viewed as compensating for an overweight trailering combination.
johnboneske
I dont disagree with you, at all! I tow a 2020 Outback 300ML which has a GVWR of 9500, with my 2003 Excursion 6.0 diesel and wouldn't want any more weight with my truck, but I was saying it could be done.
I have a Equalizer E4, and it's as good as the ProPride or Hensley in my opinion
Amacron
Louisville Ky
Just completed a 4630 mile trip out to Yellowstone and back. Avg 9.4 MPG towing an 275BH TT. I was just under the max weights. We carefully weighed everything we put in the TT. Including the propane tanks and battery. It came out to 550lbs. The TT drywight was 6480. The TT GVWR is 9480. I had it weighed at the cat scale. With everyone in the expy plus full of gas. I was at the following weights
steer axle 3400
Drive axle 4380
Trailer axle 6560
Total axle 14340
have the blue ox WDH.
I have a 2019 platinum max with the HD tow package. Watched the transmission temp. It ran 214. On the entire trip only had one rather steep grade. Where the max transmission temp hit 243 for about 2 min. Then started back down.
umshanq
Canada
steer axle 3400
Drive axle 4380
Trailer axle 6560
Total axle 14340
What's your payload on this trip?
RustyOval
Illinois
UVW
6238 lbs
Hitch Weight
604 lbs
GVWR
7995 lbs
Length
32' 0"
Height
11' 1"
GVWR: 7400
GCVWR: 15,200
Payload: 1621
Towing: 9,000
You can tow that camper, just pack light witout water and load up with groceries when you get to your destination.
M
Matthew Marlowe
San Diego
We've pretty much decided to buy the Grand Design Transcend Xplor 265 with a dry weight between 6300-6500 lbs and gvwr of 7500-7995 lbs depending on how it arrives.
We just need the layout. It does everything the 2800bh does, but with less clutter, more usable bunks, and a more spacious bathroom.
Caveats.. it doesn't have exterior ladder, dry weight doesnt include TV, no exterior kitchen, and floor insulation is reduced from imagine line.
For the first two years, while kids still at home.. we might be close to payload limit of expy..but after kids in college and minimal payload..I'm hoping we will be fine. Or maybe we will have to upgrade to newer gen expy eventually if safety concerns assuming next gen expy increases payload at all..
Pairing it with geny torsion hitch and propride wdh/antisway. A little worried that it's 32ft .. that's my biggest concern. Difficult pushing button on greater than 30ft trailer for expy...
YouTube trailer video:
Sent from my SM-T820 using Tapatalk
JasonH
Houston, TX
Safe travels! I suggest visiting a scale once you're fully loaded for a trip.
