Ac not blowing cold
josephmast94
cullowhee nc
The air coming out of my main vents and rear vents is not as cold a it use to be. I am hearing what I believe the be the rear txv hissing as the compressor cycles on and off. I just got a set of manifold gauges from O'Riley's loaner tool program, here are my readings.
Ambient - 70°
Static system pressure - 84psi equalized
High side when compressor kicks on - 125psi
Low side when compressor kicks on - 30psi
High side when compressor is cycled off - 100psi
Low side when compressor is cycled off - 50psi
What is going on? Are those numbers within an acceptable range? Should I try adding refrigerant? I am considering pulling all the refrigerant out, vacuuming, and replacing the correct amount just to see what happens.
stamp11127
Temple, Georgia
High side pressure is low according to the chart in the sticky in the Heating / Cooling section. Make sure the condenser is clean and the cooling fan & fan clutch or electric fans are running correctly. Fan shroud should also be in place.
If you can recover and recharge the system that will make things easier to diagnose - that way you are starting within specification.
johnboneske
Its all about outside temp to when charging don't forget. 30 psi low side if I remember correctly is proper charge at 60°. If it is hissing in the rear, it has a low charge. Probably will need 1 to 2 pounds to it right.
1955moose
Yeah, looks like your low but not much. Probably popping in about 10-12 ounces should bring your numbers up. I buy mine in small 12 oz cans. Be sure to wear safety glasses, and wrap a rag around can of freon as you shake it and add it to system low side. Cans get mighty cold!. You might want to have a shop do a beeper test after to see if you have any small leaks. Hopefully it's not the rear. Their harder to get at, but are usually your trouble spot.
1955moose
They seem to do that a lot around here. I think what it is, is the other websites are so dead, it takes a week or more, just to have a post answered. We're like the old Domino's Pizza delivery, 30 minutes or less!
jflip
Indy
2000 XLT 5.4- hissing noise located at rear left panel, seems to be coming from a small square metal box. I seem to hear the compressor turn on, then hissing, then the compressor cycles off, no hissing, and repeats over and over when I have my ac on.
I read that this may indicate low refrigerant, but any other insight?
FYI I have the crossover antifreeze spew happening on top of 1-4 coils/plugs/boots. I changed 1-4 plugs and cleaned the boots, and I believe bought time until the next fouling! Paid $1100 for all 8 plugs/coil/boots 8 years ago. Never again. Long term fix is to replace the intake manifold cover, right?
johnboneske
That's a sign of the AC being low on refrigerant.
jflip
Indy
Air blowing from this area, the source of the hiss. I added 12oz and it is somewhat cold, but this hiss is still happening. Any ideas as to what the hiss is? Thinking a leak of sorts. 8A523AC9-1809-489D-8A30-E5F6A6B521AC.jpeg
johnboneske
12 oz is nothing, the system holds about 3 to 3.5 pounds of R134a if I remember correctly. When charged properly it wont hiss.
