Wrench light..no codes
YMRacing
Champaign, IL USA
2017 3.5 2wd 30,000 miles owned since new.
Wrench light comes on, goes into limp mode. Called Ford. Told to shut it off, start it again and take it to the closest dealer.
They found nothing. Happened again 30 miles later. Did same, but different dealer. They found nothing.
Drive 250 miles and... didn't skip a beat.
I've got my OBD Reader hooked up anytime I'm in the vehicle now.
Any thoughts?
BlueStangGT
Oklahoma
If it hasn't returned in the last 250 miles then it may have just been a transient bad reading from a sensor. If it comes back, try disconnecting the battery overnight and see if the CEL returns after reconnecting and getting through a few driving cycles. If the CEL still returns it will likely eventually give up a code.
Robert McMillan
US
Any thoughts?
TSB for throttle body stuck open or closed. Same thing happened to mine 2 years ago they are just being lazy
Robert McMillan
US
Any thoughts?
It’ll keep popping until it’s bad enough where it will register a DTC that they can only pull with their scanners at dealership. I witnessed this first hand
rjdelp7
2000 XLT
NY
The wrench light is a major powertrain fault. The Ford V10 work trucks I drove, usually were throttle body issues(@200K mi). It could also be a transmission issue. The throttle position sensor, helps tell the transmission when to shift. Have you notice your idle is off? It needs to be checked out.
Robert McMillan
US
Not technically “major” as it can go away after you cycle truck off and back on. Mine ended up being throttle body issue. Replaced same day
91fox
I have a friend with a f150 Ecoboost, who had something similar happen to his truck. He would be able to drive it for miles on end without issue, however, when he really womped on it with the engine cold it seemed to go into limp mode... I hooked up the scanner and told him to floor it, service light came on and ding ding ding.. it was a bad coil, if I remember right it was #6. Not sure if this helps you, but if you have access to a scanner hook it up and have someone really get on it while you watch the scanner, see what it says.
Robert McMillan
US
Your friend is a f—-ing moron for “womping on it with the engine cold” and so are you if you did this. You probably blew that coil out doing that and still have another underlying issue. You’re an idiot
91fox
I'm sorry you feel that way. However, if the engine is that delicate to not be able to handle a brief load when it's first started then it shouldn't ever have been sold to the public. It was an ignition coil, and it resolved his problem. The truck has been fine ever since. And by the way, my friend lived on a hill, and when he first left his house in the morning the issue was most apparent... I wouldn't cast doubt on someone else's experience that actually fixed a problem.
Robert McMillan
US
You obviously know nothing about how ecoboosts work then. You give it zero time for any type of warm up and just slam on it right out the gate you’re asking for issues. But hey, your truck not mine. Let us know how long yours lasts!
07navi
Mt.Shasta California
He was just testing it, give him a break and don't call people names.
Robert McMillan
US
Just stating the obvious, Not sure I know anyone who would turn their vehicle on and immediately floor it. Sounds like a stupid idea especially with a coolant/oil cooled twin turbo setup
