2015 expedition el A/C
michealmyers
MS
Anybody had problems with the A/C connections under the passenger dash? My 2015 A/C will stop blowing sometimes after the wires have been touched/moved a bit by passenger feet, bags, etc. I read where I think the purple wire sometimes comes loose from that connection, not sure if thats correct or not.
2012EL3RDGEN
Tucson, AZ
There are known issues with the harness. Ford sells a part to redo the wiring. Just ensure you get actual Ford parts and change the resistor it plugs into at the same time those are usually fried a bit. I think the exact parts have been discussed here before.
Sent from my SM-G965U using Tapatalk
Eric Wheeler
Denver area
ditto on what you said. Use OEM on both the resistor and the new connection. 1 cable is smaller than the rest and it's OK. Just bringing it up because I was wondering myself. Also make sure you get the right one. There's 1 for manual AC and Auto AC.
M
michealmyers
MS
ok so 3U2Z-14d dS411-ZEA or CU2Z-14S411-FA would be he part I need?
adamsdaddy
Orange County
Muddy Bean
Just did this to my ‘15 yesterday after having intermittent blower issues for the last couple of months. Works like a charm now.
