Lower Valance
kodigray2015
Well my wife finally decided today (own her own) that the lower valance on the front bumper needed to go. Needless to say I did not argue and it looks so much better.
I still don’t understand why they put these on in the first place. To me it looks like it will cause wind drag.
dlcorbett
Air Force
tx
I believe its an air skirt, it directs the air flow for better hwy mileage.
techdude99
US
Correct, it helps minimize the turbulence under the truck. This equates to a more stable ride and improved gas mileage at highway speeds.
Expedition Dave
A Tiny Little Dot in Florida
They are believed to be quite effective, and I have heard rumors of a 1 mpg or more difference at highway speeds. It is probably exponential, so the faster you go, the more mileage you will lose. TTBOMK, the FX4 has a more truncated version. I do not know the degree of one vs. the other, but eventually I will remove mine, and add it for longer highway trips.
K
kodigray2015
I just don’t see how they are fuel efficient. It would be different if they curved back some instead of being a flat wall, plus it just looks stupid on the front.
techdude99
US
It's definitely not for esthetics.
The extensive wind tunnel and real world scientific testing by auto manufacturers necessitated the need for it to maximize airflow for better efficiency. All vehicles, going back decades, have some variation.
I personally hate how it looks.
Removing it will have some minor effects on gas mileage. Just like disabling the engine auto-stop/start feature.
Every little bit helps the auto companies meet EPA standards. It's a balancing act. Multiply small gains in MPG over thousands of vehicles and there's the main reason.
Craigga542
Kansas
Robert will deny and argue like crazy, but it’s a fact and just plain engineering. References are all over the place, same reason a lift decreases mileage. Ask any engineer or plug some info into a wind tunnel software or better yet a real wind tunnel. Dave is correct that it’s exponential the faster you go, or if you have a strong headwind. It could be upwards of 1 mpg at 70+ mpg, but I don’t have specific data on the Expedition nor access to the software personally. References below should be good enough, the Expedition would see higher gains that these examples. Either way, question is does it matter to you. I’ll be pulling mine off soon, debatable if I’ll install it for long trips.
https://www.verus-engineering.com/blog/cfd-cases-4/post/air-dam-or-splitter-a-closer-look-12
http://www.grandmarq.net/blaze/Blaze_Pics/AE 507 lect 7 Aero Drag of Autos.pdf
Reference page 17-19. On a VW Rabbit, air dam equates to .02 Cd.
https://commons.lib.jmu.edu/cgi/viewcontent.cgi?article=1271&context=honors201019
Reference page 44. 06 Range Rover Sport with a Cd of .68. I believe the Expedition is around .39? Front air dam only decreased drag 14.5% or .1 Cd. That’s a substantial decrease
K
kodigray2015
Well they way I look at it, personally for me the thing looks stupid & ugly (personal opinion). It is some what of a pia to get off since you have to remove several plastic clips, several 10mm bolts, wheel well bolts in the front, and the spring clips for said wheel well bolts. Probably a total of 20-30 minutes worth of time. For me to lose up to 1 mpg, I think I can deal with that for the trade off of a better looking vehicle.
So the seldom trips that would put me on the interstate to be driving long distances at 70+ mph just to possibly lose 27 miles on a full tank of gas are few and far between per year. I believe I can deal with that. It is each person choice to decide if the y are good with losing a little gas mileage to make there expy look better (personal opinion). There is probably less mileage loss to doing this than putting a storage rack or light bar on the roof rack.
Deadman
They want as little air going under the vehicle as possible, because it all causes drag when it encounters the underbody components. It also helps the airflow thru the radiator, by creating a negative pressure underneath it so more air can go thru the radiator for cooling.
Craigga542
Kansas
I agree, all a matter of opinion. I frequently drive above 70 and take longs trips yet I still may take it off, it’s ugly. I care a lot about efficiency but again I didn’t buy this thing for mpg. I also use it in light off road situations where ground clearance matters, if I don’t remove it there’s no way it’ll survive.
FWIW, the manual does mention removing it for off road situations. For driving below 60, I’m guessing you wouldn’t even notice it whether there was a headwind or not.
Lou Hamilton
Took it off within a month of owning mine. ;)
I did not buy it for gas mileage. I bought it to tow. :)
Fozzy
Riverton
My 17’ Superduty has a huge one. And if you take it off you will see part of the frame horns. At least the Expy gives you a clean look without it.
Robert McMillan
US
I cut 4” off of mine on both my 16s, saw no loss in mpg at any speed, saw no performance differences and saw zero increase in any type of engine or coolant temps. It’s a piece of plastic that can just be trashed
Robert McMillan
US
there’s zero difference in efficiency and even if there was it would be less than 1%. My family has owned multiple vehicles over the past 15 years, 4 SUVs, a mustang, f350s all of them have had those ugly valences removed and not one single difference in efficiency or anything has ever been noticed to say “oh shit I better put this back on”
sure in a laboratory setup in perfect conditions they may see differences but we don’t drive in f-ing wind tunnels in perfect conditions do we fellas?
Greg Parker
Arizona
My buddy nearly ripped his off (of an F150) going down some pretty mundane two-tracks in an area that we hunt. The damn things steal nearly 2-inches of ground clearance. Fortunately, I had my toolkit with me and we took it off when we got back to camp. He's never put it back on in the 4 years he's owned the truck (I think it's a 2016, maybe a 2017 ...but basically the same stance as our Expy's). Anyway, I told him he might want to put it back on for gas mileage; however, he said he noticed NO CHANGE in MPG and decided to leave it off.
I haven't taken mine off ...yet; however, I've only owned it for a little over a month. It'll definitely be coming off the first time we go boondocking or when I go hunting in October.
Lou Hamilton
There is a YouTube guy that replaced his with a low profile one. It covers the frame and looks a whole lot better.
I will try to see if I can find him. I want to say his name is something like workandplay or something. He uses his trucks for plowing in the winter and stuff, but added a 2019 or 2020 F250 to his cadre of trucks.
