Transmission Shift Delay
ETC13
TN
Problem is we don’t know if one guys 2-3 seconds is the same as another guys 2-3 seconds. I’m trying to think of a car that had instantaneous engagement. Maybe my old TA with 4l60 or one of the 727 mopars I had felt like it popped in right away. Most anything is going to need a split second or full second to get fluid started.
Does it start after a certain number of miles? I have 2500 so far and I’ve never thought it took longer than it should and I’m pretty sure nobody else on earth has as many quick back and forths as I do to get in or out of my garage.
The expectation is put truck in gear take foot of brake press gas and go....so I don't think anyone said anything about instantaneous.
For those having the issue it is the above scenario and you press the gas and the truck is simply still not in gear. We aren't talking about bank robbery I need to get gone now type of scenarios. It is lazy Sunday morning type of drinking your coffee still and the thing simply still isn't in gear after it really should be. You can sometimes lift off the gas and hit it again and it isn't in gear still. So it is a solid 2-3 seconds.
Note: not in gear for above means not responding to the throttle input.
Sent from my moto g(7) using Tapatalk
Expedition Dave
A Tiny Little Dot in Florida
Maybe if we had a delay
Maybe if we had a delay we’d know what you’re talking about.
So it goes in instantly? As soon as you turn the dial into gear? Further, it is episodic for me, but even under the best circumstances the slowest gear change for any of the 50+ vehicles I have ever owned/rented/borrowed/driven.
grumpyoleman
flyover country
I am curious about this issue as it seems random. I have an '18 XLT Max just over 12k miles and I had to go out and drive around a bit while paying attention.
While the shifting is not instantaneous (no electronic shifter is are they?) there was no 2-3 second delay. Every time I shift from P/D, R/D or D/R, it engages before i even get my hand off the dial.
I know this doesn't contribute much to resolving the issue, but I do agree that not all vehicles seem to be doing it.
R
If all vehicles don't do it, then this is an indication that it's to Ford's intent by design. True?
Fozzy
Riverton
My $0.02. When I first got it I felt there was more shift delay than normal. But I also struggled with the rotary knob. I would get the occasional clunk here and there as well. Now I get the knob in and out of gear and right at the detent every time and I don’t feel it’s to bad. I have gotten better with the shifter and grown accustom to its slower shift than a direct cable or linkage.
Dice Roll
Craps Table
mine pops in gear a brief time after I turn the dial. Haven’t thought it was different than any of the many trans I’ve had over the years. I mean, I’m a gear head and I’m quick to question a plugged filter, pump going away, or converter issue. So far this has been as good of a trans as I can remember having. Maybe that will change with some miles.
ETC13
TN
I am starting to wonder if it is the throttle response that isn't kicking in sometimes. I will have to pay attention to if the rpms rev or not next time.
Dice Roll
Craps Table
Wife drove for two hours today, we unloaded it then I pulled it in garage. Tested for a delay and it was quick as can be. Forward and reverse. Repeatedly. If a dealer claims it’s normal, it’s not. Mine went over 2600 miles today.
armoredsaint
try doing it in actual road conditions and giving it gas, switching it back and forth stationary in your garage isn't the same
R
I agree. I did a 3-point turn yesterday. I hit the gas thinking it was in gear, but it was still in the delayed state. When the truck finally went into gear, the potential from the gas I applied resulted in a sudden esseleration in reverse. The vehicle felt a little bit out of control. I will be taking it in.
Dice Roll
Craps Table
what? It’s as hot as it can get without a trailer after two hours. Jacking it into position in my garage is going from forward to reverse multiple times is as good a test as any.
I also don’t change gears unless stationary. That may be your problem right there. Doing shit like that will **** up a transmission. The engineers might have designed a delay to help keep the damage down. I didn’t think about it as a protection measure, but I also don’t warranty these things. Something for them to account for.
Jamaican Cruiser
Vienna, VA
I did some research on this after buying my 2019 Expedition about a year ago. I have a friend who is an engineer with Ford and his explanation is that with the knob shifter, there needed to be a delay (1-3 seconds depending on the situation) to prevent stripping the gears when the vehicle is rolling. For example, if you are coming to a stop driving forward but have not stopped and you move the knob into reverse the system is designed to delay engaging to prevent stripping the gears. If you ever have shifter gear without stopping the vehicle, you might have heard that awful popping/grinding noise.
Not sure I fully buy the story, but he is sticking to it :D
ETC13
TN
Then they did something wrong in the design. Vehicle is fully stopped when I am moving the knob to drive. Sounds like the delay is there regardless of vehicle stopped, etc...
This lines up with how mine reacts. Turn the knob, take foot off of brake and press the accelerator and nothing. Press again and truck goes...
Over engineered POS design.
