jeff kushner
Turned 97,000 as I rolled out of my local shop last Friday after replacing the original tires which had been rotated only 3 times in 97K. Replaced with same Hankook tires, now the Dynapro AT2.
It was it's first time on a lift....replaced rear brakes at the same time(front pads were done 10k ago or so, plugs replaced at 86K. The rear fluid was changed using outboard gear oil and the Ford additive 40K ago, cleaned up the slippage and never has been an issue.
My truck has never been to a repair shop. Nothing has broken, no fluid or H2O leaks anywhere, no errors. It required a bit of MAF cleaner to clean the TB at 90K or so, cleaned it right up.
Bought new in Nov '16 it's coming up on 4 years of ownership....by far, the best of the 3 expy's I've owned.
jeff
jeff
