Level kit
stefan gimenez
Long Island
I am to understand that the F150 front struts mount the same as the Expedition so in theory an f150 level kit should work?
Big H
New Jersey
No, two very different set ups. Get the ready lift kit, don’t try to cross fit with F-150 parts.
sanman28
SW MO
No. The only F150 suspension item that has shown success is the 5100 front shocks from an F150 4x4. On the lowest setting they give your expy about 3" of front lift.
Expedition Dave
A Tiny Little Dot in Florida
I also imagine, a 3 inch lift w/o the rear Expy shocks maxed out (1.5 inch) in back will look very strange.
I am not even 100% sure with the Bilstein 5100 3 inch / 1.5 inch combo they are truly level or slightly "nose high" at rest?
YMMV
S
stefan gimenez
Long Island
The ready lift level kit for the F-150 and expedition are the same part number. So they must be the same mounting holes
Big H
New Jersey
Hi Stefan,
The ready lift kit is the same no difference. Only difference is if your expedition has the CCD shocks then you need the new kit that includes the front CCD brackets.
But if you are looking at the 5100 shocks, only the front ones are compatible between the F150 and expedition.
Ready lift kit is only spacers that sit on top of your existing shocks. Whereas the 5100 is an actual shock absorber.
