Hdfxrs
Not happy with the 4-wheel drive selector in my 2018 Platinum. It only goes into 4-wheel auto. No way to select 4-wheel full time. Is there a way to program the computer to do this? I believe the other models have this function.
Get a tow package.....
I thought the drives modes helps controls 4wd?
Mud/ruts drive mode gets you 4H. See below from the 2019 manual. View attachment 39128
Thanks for the help. I’ll try the rotary switch in mud/rut. We have 6 inches of snow today and a long uphill driveway. I just want to keep the front drive engaged.
I do find it annoying thought that, for example when I put it in Snow mode, that when I shut off the vehicle and start driving again, it goes automatically goes back to normal but leaves the vehicle in 4A. Seems dumb, if you're going to default back to Normal each time, then go back to 2W as well. Otherwise, stay in the mode I put you in to begin with.
My driveway is seriously steep. I used to have to power up it in the 250, my 17 Expedition EL in 4A went right up it, both forwards and backwards. Haven't had the 20 in snow yet, but based on its behavior even with the crappy highway OEM tires in the Mud it will also have no issue. Just leave it in 4A, 50/50 might not be what you need. Letting it send power back and forth might be exactly what you need. Try it.
It’s all in the weight distribution. My dad has an F-250 crew cab with the e-locker and I can enter the steep side drive (garbage truck entrance) into one of our apartment complexes in 2H with the Expedition when he can’t make it even with the locker on. He needs to use 4x4. This winter I’ll be having to plow that steep drive with the 250 since he’s going through chemo that should be fun. There’s just no weight over those rear wheels on the pickup.
The info on link is exactly what I needed to know. I went skiing in March and had my 2019 Expy in Normal mode and 4WD (4A). I don't have tow package or the FX4 package. Going slow and coming out of turn in the mountains, the rear started to fish tail but luckily it straightened out. It scared the heck out of me. The other side of the road was a shear drop off and my son was in the Expy. Next time, I'll use the mud/rut/sand mode so that the Expy is locked in 4H. Thank you guys! This is extremely helpful.
