Okgearhead
I have a 2017 Limited EL and would like to add auto up and down windows for all my windows, not just the drivers window, does anybody know if the Platinum has all auto up and down windows ?
It does not. The Driver switch actually has a secondary position, that allows the function to work with additional programming. So, the switch would have to be swapped for the other 3 positions and possibly programming.
Maybe see if the Navigator 15-17 has Auto Up/Down, cause not sure on that?
My '07 Navigator has auto up and down.It does not. The Driver switch actually has a secondary position, that allows the function to work with additional programming. So, the switch would have to be swapped for the other 3 positions and possibly programming.
Just on the drivers door.For all four, the front, or just drivers door, cause our 17 Expedition had it for the drivers but not the others.
I was just clarifying that it was a physical difference in the switches. Also, the 07 does not have the same switches as the 15-17’s...
Would this work?
https://www.ebay.com/itm/For-Lincoln-Navigator-15-17-Motorcraft-SW7511-Front-Driver-Side-Window-Switch/283326080275?epid=210394565&hash=item41f78ce513:g:AgQAAOSwfMlcLhNc&fits=Year:2016|Model:Navigator|Make:Lincoln
I have always wanted the same feature myself. This won't give you all four, but is better than what's currently available.
