Okgearhead
I have a 2017 Limited EL and would like to add auto up and down windows for all my windows, not just the drivers window, does anybody know if the Platinum has all auto up and down windows ?
It does not. The Driver switch actually has a secondary position, that allows the function to work with additional programming. So, the switch would have to be swapped for the other 3 positions and possibly programming.
Maybe see if the Navigator 15-17 has Auto Up/Down, cause not sure on that?
My '07 Navigator has auto up and down.It does not. The Driver switch actually has a secondary position, that allows the function to work with additional programming. So, the switch would have to be swapped for the other 3 positions and possibly programming.
Just on the drivers door.For all four, the front, or just drivers door, cause our 17 Expedition had it for the drivers but not the others.
I was just clarifying that it was a physical difference in the switches. Also, the 07 does not have the same switches as the 15-17’s...
Would this work?
https://www.ebay.com/itm/For-Lincoln-Navigator-15-17-Motorcraft-SW7511-Front-Driver-Side-Window-Switch/283326080275?epid=210394565&hash=item41f78ce513:g:AgQAAOSwfMlcLhNc&fits=Year:2016|Model:Navigator|Make:Lincoln
I have always wanted the same feature myself. This won't give you all four, but is better than what's currently available.
Just a little info, you don't have to be snarky. Maybe someone found it interesting.............and keep your soggy beer.So Zero added value to the thread, because different switch, and same function as a 15-17 Limited Expedition...
THanks!![]()
This has actually been on my todo list for a while. The motors and wiring are different. If you can get a passenger window motor from a Navigator and add all the missing wires I think it should work. I pulled a motor from the junk yard a while ago but haven't had time to figure out the rest of it
I have a 17 Expedition. I think the Navigator I pulled the motor from was a 15 (I know it was 15-17 but not sure of the year in that range)
One touch motor has an 8 pin connector. Regular motor has a 2 pin connector.
Comparing the driver and existing passenger side on my Expedition it appears that the one touch motor gets an always hot line from the BCM and the switch just sends up/down commands. Best I can tell the brains are built into the motor assembly
One touch up and down? If water gets on those switches from an open window it can ruin them.Would love this feature, especially because currently my one-touch up only works 1/3 of the time. Please post results when someone does it.
Still being negative...............Just like any switch. No more risk than the regular switch. I have NEVER had a window switch go bad from getting rain on them.
