Big H
New Jersey
Also, has anyone found fender flares for this rig yet? I have searched everywhere but nothing comes up.
StealthyD
Gulfport MS
What are the cons with this set up @Fozzy?
I was thinking of doing -44 as well with the 3/2 lift kit.
With any vehicle running a large negative offset I’d say it’d have to be rubbing, and hubs eventually hating you.
Big H
New Jersey
Yes, agree on the hubs for sure. But I have the warranty till 150k miles or 10 years. Hubs are covered for me for that timeframe.
The rubbing I’m fine with, no issue to trim the wheel wells and possibly fabricate elongated upper control arms to get the wheels in spec for alignment either.
Any other issues I’m missing?
StealthyD
Gulfport MS
And also side of truck staying dirty. The front hubs on my super duty were all dynatrac and they still needed replaced every 18mo or so on 20x12’s - 44 offset. That plus 4x4 launches
Fozzy
Riverton
Moving the wheel out almost 3.5” and adding 3” to the width of the wheel can’t be good for any suspension components. There is no way it doesn’t rub like crazy or even allow for normal use. From what people post on here. I should be able to put +18’s on my ride and clear 37’s rub free after all my trimming to clear what I have. I say go for it. If it works I will get 37’s.
Big H
New Jersey
Worst case, I’ll just throw on the Toyo Open Country AT III 33 x 12.5 R22 on my stock wheels with a 1” spacer in the rear. Also polish and ceramic coat the rims when I swap tires as well.
DWs-TTEB
Evans, GA
@Fozzy measured how much the wheel sticks out of the wheel well today. It’s 3/4”. With a tire on there it may max out to 1.5” or 1”.
DWs-TTEB
Evans, GA
:) Hopefully mine won’t go out more than 1/2”+ what you have there. I can live with that. If it looks like I have 5”-6” of tire in the wind I’m selling this set of new tires/rims.o_O
Lou Hamilton
Here is mine with the 12.50 tire.
Mine will be the same offset as yours, but 34” tall and 11.5” wide.
Going with 285/70 R18 Nitto Ridge Grapplers.
DWs-TTEB
Evans, GA
Fozzy’s wheels are +12mm offset
Mine are -12mm offset
what is your offset going to be?
