2020 XLT Stereo Upgrade
TBaganATX
Buda
I’m working on this as well. Just bought Hertz 6.5 Components for the rear doors, JL 800x8 amp, 55sqft soundmat. Still on the fence of front speakers and where I will install a sub. I know the limited and plats have like 16 speakers compared to my 9. Anyone know all those locations, or how to find them? I know the 3rd row has to suck fo now sound. I thought maybe some illusion audio for the rear hatch of it is deep enough & the speakers are shallow enough.. thoughts?
Aspen03
Indianapolis
I'm considering changing out the speakers and adding a sub and an amp in my 2020 no B&O Expy. I was considering getting an LCI6 LOC, but realized that it didn't have accubass. Is the FORSCAN solution working well for you?
Thanks,
Trev
The LC7i is what you're after if you want Accubass. Its a great piece of equipment. Audio Control also has a few amps with a built in LCi that handle signal summing, etc. Depending in your goals you might check out some of their DSP amps.
8131full
Las Vegas
After some research, Ford actually tunes out bass for their low end speakers to keep them from blowing, especially at high volume. I was about to install a LOC converter to fix the issue (another $180), when I came across a FORSCAN code(s) that deletes out the factory sound tuning and knocks the signal down to pre-amp levels. Both codes 100% worked on Expedition (the non-Sony code):
Is this true for all Fords, or Just Expy's? What model year range?
Anthony DeVor
Just bought a 2020 Expedition Max with the 202A option package that had a few other options (i.e. Nav., Captain’s chairs, sunroof). Opted for this over the Limited due to about a roughly $6,500 price difference when similarly equipped. My kids are just going to wipe buggers on the inside anyway. However, I just couldn’t take the 6 speaker stereo. I’m not looking for amazing sound, but this stereo is weak. I’m totally fine with the stock Bose setup in my Q7 and Boxster, but this just wasn’t going to work.
So at 350 miles all the door panels came off, and new speakers went in. Also put in a Rockford Fosgate PBR300X4 amp which fit nicely in the extra space towards the dash under the center console (a bit up from the cupholders). Hopefully it won’t overheat (time will tell). I retained the factory head and spliced in to the factory harness (using line level inputs). Made me queasy in the process, but all went fine.
Project is almost done, and it sounds much better. Not perfect, but not like crap like before. I can hear the stereo now over the road noise.
However, just wanted to post a few ideas that might help:
Easiest point I found to run power for the amp was the grommet for the hood release cable on the driver side. Unfortunately, that’s opposite the battery so it’s not ideal, but it’s easy to reach.
Tweeter wire feed for front A posts actually split off in the door at the factory speaker, not the head unit. Made using the aftermarket speaker crossovers (mounted in the door) very easy. I retained all factory wiring.
Cutting holes in the rear door panel for new tweeters with a dremel is very easy. There are already holes (probably for the B&O system) in the back of the panel that almost act as a guide.
System still lacks deep bass, but for a $700ish upgrade, I wasn’t expecting a ton of bass. The sound is a bit “crisp” but I don’t hate the sound anymore.
Last step is the Forscan removal of the fake engine noise (and auto start), which I’ll work on soon.
There are grommets on the floor under the carpet in front of both seats on both sides there are two different size grommets
J
JKautz
Sacramento
JKautz. Thanks for paving the way. Could you provide feedback on this question and Nalnevin's request for photos and parts? Thanks.
Sorry, I don’t check in here much. It’s better for people to email me ([email protected]) if they have questions.
The upgrade does help with the third row, but sound is still limited. My daughter is in the 3rd row a lot, and hasn’t really complained about sound after the upgrade. The higher trim level Expeditions have speakers in the rear pillars near the liftgate which I assume is for the third row. I have a PDF I can send showing where it is if anyone wants it.
I’m still happy with my Forscan fix for the EQ. I actually ordered a aftermarket equalizer, a LC6i, and returned it because i didn’t need it.
Added a tweater in the factory spot in the rear door (lots of dremel use)
Backside of the rear tweeter install.
Front A pillar tweeter replacement (yes, I used hot glue, and have had no issues).
Front door. Yellow area is where I mounted a thin piece of ABS plastic and then mounted the crossover.
Amp buried below the gear selector in the center “dash” area.
SWTB0BCAT
Thanks for posting these pictures. I am looking to make upgrades to my 2020 6 speaker system soon. Still looking for a little guidance on speakers, amps, etc. A sub would be nice also.
wiscoford
