Jozef Zoldos
Got a 2011 Expedtion EL Limited. Put in new cam phasers last year and put in an upgraded oil pump (Melling). Over a year later, oil pressure light comes on at stop light and pressure guage on dash falls. This happened about 2-3 weeks ago during a simple commute then stopped spontaneously. Symptoms just recurred and stopped again (about 2-3 weeks later). Car runs perfectly without a hiccup. Did an oil change 1 week prior ot all of this and oil levels are OK. I realize that the oil pressure sending unit is an idiot switch and they are known to go bad. What are the chances that it is a bad oil pump? What would you all recommend? Should I test the oil pressure with a guage or should I just try to change the sending unit?
