Rear locker vs 4L
Expedition Dave
A Tiny Little Dot in Florida
What's funny is the only two options I truly wanted, I got: FX4 and HD tow package.
And while I have never bothered with anything less, the 3.73s sure make this thing quite quick on its feet, and if you feed her 91+ octane, even more so.
If they offered 4.10s, would I take 'em? Only if I towed on the the 9K edge or this thing came with 33-34 inch tires, stock LOL!
Anerbe
Mi
I personally find benefit of rear lockers vs. 4L, although each have their benefits. The con's don't make sense, as both can be deactivated.
Brake modulation differentials works when you don't need high torque - slippery relatively flat roads, or you have an overabundance of torque available (McLaren uses brake diffs). Your available power will split between the braked low traction wheel and the wheel with traction (you only get up to 50% of the power) since the car is simulating a resistance with brakes on the low traction side to equal the resistance on the traction side.
If you're doing some major climb off roading, pulling a heavy load over uneven/slippery terrain, or any application where you cannot afford to run at 50% power to a tractive side, locking diffs are key. Being 100% locked between the rear wheels, either corner uses the full power of 100% up to the traction available, with no slip sensing / reactions.
Rear lockers with 4wd makes the car essentially 3 fully time driven wheels, without brake modulation. 4L alone is still open diff between each axle, so there are scenarios where you can still struggle. In an instance of the right side in an icy ditch, left side high on pavement, 4wd open diffs will act like a 2wd vehicle. You will get 0% power to the left side without brake modulation, and 50% power to the total left side, 25%/25% each front left and rear left with brake modulation. In the same scenario with ELRD, 4wd and brake modulation, you should be getting a total of up to 75% power to the left side, as you don't waste 25% to the right rear, therefore left rear gets 50%, front left gets 25%. These scenarios assume that the traction available between front and rear left is equal, and the center diff is not redistributing power between front and rear.
Bo Simmons
Atlanta Ga
Armin, curious what options you desire on the Limited that are not available in the XLT with the FX4 package? We are based in Georgia but plan a move out west to a Mtn town in the future, so I purchased the XLT with the FX4 package. I'd like to have added the variable cruise control but otherwise very happy what i have for the price point. Also thanks for the post it helped me learn a bit more.
Calidad
FX4 would be fine, except I'm just not sold yet on the fixed running boards, plus the mandatory moonroof on the Limited.
But you all have now convinced me I should not worry about the 3.73 axel. So in the end it probably will come down to what price I can get, and indeed negotiate some better tires.
There are much steeper discounts on the higher priced models btw.
The platinums don’t sell well due to their sticker scaring people away. My platinum cost me $500 more than a Limited the same dealer was trying to sell me with far less incentive to deal.
I got 12k off msrp on my platinum
A
Armin
Cascades, WA
@Bo Simmons the non-fixed running boards, folding side mirrors, forward sensors and the a bit nicer interior. It is all a matter of taste of course.
In essence the Limited 300 package is what I'd like, but if the price is good I may even do the Stealth package, despite that moonroof. Ever since I had this expensive non-warranty claimable leaking sliding roof window (for which fortunately Ford waived the cost almost completely) my appetite for the roof-window has gone to "dont use - dont care" to "rather not". But that Stealth package does look nice ...
I’m confused what this threads meaning is since usually both 4L and the locker are in the same packages. 4x4 is always superior to a locker alone, if it’s a 2WD with locker vs a 4x4 with open diffs the 4x4 will always be more capable. My dads F-250 with locker on only can’t do half the stuff it can do in 4 low with the locker off. Both together is the best.
shane_th_ee
Seattle
For 2021, the 3.73 eLSD is now a stand alone option.
A
Armin
Cascades, WA
... and even worse, if you pick eLSD you cannot pick HD tow for some reason.
Since HD tow and FX4 are the only two options that give 4L in 2021, this means picking eLSD means no 4L unless you take FX4.
But taking FX4 limits you to XLT or Limited with 301A package. You want one of the other 3 packages with Limited, or want King Ranch or Platinum? Well, then no HD tow - and hence no 4L - for you when you select eLSD.
I'm assuming Ford did this based on its actual sales data, but it seems odd to me not just offering the eLSD on any 3.73 axel truck.
shane_th_ee
Seattle
The eLSD is the 3.73 and is included in the HD tow and the FX4 packages. I think the fact that you can pick the eLSD and then pick the FX4 but not the HD tow is just an error on the configurator website. In other words, i don’t believe you can get 4L without also getting the eLSD.
A
Armin
Cascades, WA
I hope so, but doubt it:
- Selecting HD tow removes eLSD and visa versa.
- HD tow is cheaper than the eLSD which is illogical if HD tow is a super-set.
- eLSD is not mentioned in the HD tow detail description.
So that would be a logically consistent error :angels25:
The fact you can select eLSD and then FX4 (which includes eLSD) is not an error actually. It deducts the eLSD separate $1100 price when you select FX4 (but as you must then take the 301A package the price still goes up, cloaking this perhaps unless you watch the exact dollar amounts).
UPDATE/EDIT: Actually indeed it is an error. Looking at some actual window stickers, you can get HD tow with also taking eLSD.
In fact I could not find a single car without eLSD when HD tow was present. If indeed so, then the website error is that HD tow and eLSD are listed as mutually exclusive, when in fact they should probbaly work like the FX4 package where HD tow should be priced at 1100+795.
shane_th_ee
Seattle
Hmm... And I see the price of the HD tow package is now only $800 and includes no mention of the eLSD. And yet the 2021 trailer towing guide (google it) still requires the 3.73 rear axle for the >6000lb tow rating...
Didn’t know that change was made.
Rear Locker>2WD
4WD>Rear Locker
4WD w/ locker>4WD
I’d take 4x4 Low myself if it’s between the two, but I launch a boat so that’s why. LOW is wanted if you do anything that requires high torque multiplication or crawling. Launching a boat, sand, etc all call for 4x4 low because excessive wheel spin will get you into trouble.
Side note I got my Expedition stuck in a ditch going to a buddies cabin about 2 weeks ago. I wished I had a locker then to at least try. It my have not been enough as I was buried and sideways, but who knows. 4x4 Low was the only mode that let the truck move, but it just went back and forth in the ditch I couldn’t turn out of it. 4 auto and 4 High did absolutely nothing, 4 low moved the truck back and forth. So something is to be said for the low range, not sure if it was the gearing reduction or the programming.
A
Armin
Cascades, WA
@shane_th_ee / @JExpedition07 - I updated my previous reply, but it probably crossed your two replies:
In fact I could not find a single car without eLSD when HD tow was present. If indeed so, then the website error is that HD tow and eLSD are listed as mutually exclusive, when in fact they should probably work like the FX4 package where HD tow should be priced at 1100+795.
But either way the website is wrong as my prefered dealership has a Limited with both HD tow and eLSD, and I saw various others in my area with other dealerships.
shane_th_ee
Seattle
I was busy hunting down window stickers, just like you. Like you, every vehicle I saw with the HD tow package also had the 3.73 eLSD (with the 3.73 eLSD listed as a separate option).
Calidad
These modern super trick modes vehicles its a fair guess the transfer case in 4low also gets some type of center elocking logic sort of a modern version of the old center locker on the Toyotas which does make a large difference over basic 4x4.
Fozzy
Riverton
Rear Locker>2WD
4WD>Rear Locker
4WD w/ locker>4WD
I have never used 4L launching or retrieving my boat. I have launched on some pretty sketchy ramps and off beaches. Do you have a monster boat with a huge draft? I love using the locker at the ramp. My last four vehicles have had it. Comes right out with very little spin if any. Engages and disengaged easily and while moving. But I have a small 24’ runabout and don’t have to even get my bumper in the water.
Dice Roll
Craps Table
I hate sunroofs with a passion, but have learned to live with it for the superior vehicle that’s under it.
the stealth is cool and gets you the ccd and better wheels. I got the SE that named me those two things along with the tow package. Find a way to max out the value around you and the sunroof is no big deal. I forget I even have the stupid thing since the innner liner covers so well.
Therabbittree
Red Hook, NY
Fyi the expedition doesnt have a locker it has electronic limited slip. The superduty and f150 get electronic locker . There is a difference. Another forum member was looking at swapping the locker carrier into the expedition rear independant axle center section. It boils down to not easy to do
Fizzy
Alberta, Canada
Nope.
As per the manual for the 2020 Expedition:
Locking Function
me0pomQ.jpg The lock button engages ‘locker mode’.
With the locker engaged, the system electronically locks the differential causing both half shafts to turn at the same rate. This increases traction during off road events.
The locker mode may automatically disengage based on certain conditions such as vehicle speed. When engaged, a telltale in the instrument cluster will illuminate amber and the switch button will be illuminated. When the speed is exceeded the telltale will turn gray, the locker will be disengaged and be in standby mode until the speed conditions are met. If the eLSD system is faulted and the locker cannot engage, a warning message will be displayed in the instrument cluster and the switch button will flash.
