should I trust a ford dealer to install my engine
Gramp12
Portland , OR
We own a 2014 ford Expedition, EL 4D 4X4 Limited that has 86263miles.
It is currently at a Ford Dealer.
According to the Ford Dealer it needs a Long Block with an estimated repair charge of 8690.95
We have always had the car serviced at a Ford dealer.
I am trying to decide if I can trust the Ford dealer or should I find an independent mechanic or shop.
ManUpOrShutUp
Take it to an independent mechanic. There have been numerous threads here wherein the dealer told someone they needed a new engine and after a trip to an independent shop, the repair ended up being far less serious and costing hundreds rather than thousands. I wouldn't take my truck to the dealer for an oil change let alone a potentially major engine problem.
gymfamily5
oregon
Hey Ham, i posted on your other question regarding a mechanic near salem, Accelerated automotive in hillsboro. Chris is honest, reliable and resonable and backs his work!
G
Gramp12
Portland , OR
This is the dealer’s diagnosis:
Diag system KOEO Pull code P0304 cyl 4 misfire. Perform power balance Confirm # 4 is low. Perform manual pressure test #4 0 psi. Scope cylinder looks like something got in the cylinder and beat the piston and wall up. Truck needs long block.
I took it to a dealer because the car has always been serviced at a Ford Dealer.
ManUpOrShutUp
Yeah, we got that. That's generally the nature of systematic bad decisions. It becomes so routine that doing anything else isn't eve considered.
Whether the diagnosis is right or wrong, you will get more reliable diagnosis from a good independent shop and, moreover, the repair (if genuinely needed) will cost you less as well. If you have already decided to let the dealership go forward and were looking for reaffirmation for that decision here, you were barking up the wrong tree. :D
00XTL
North Carolina
Do you know if the pulled the valve cover on the side. Cylinder four is back passenger side of the engine under the firewall. I cant imagine something got into the engine from the intake. I’m just curious to know if a vale dropped or something.
In plain words. Something doesn’t JUST get into an engine.
JamaicaJoe
Oviedo FL
It would be simple enough to ask the dealer to show the damage with a borescope. The engine could have hydrolocked with coolant from a head gasket leak, or fuel from a bad injector.
joethefordguy
I'm going to make the wild assumption that the dealership can be trusted to install an engine. Hell, if I can do it, they should be able to.
HOWEVER...
I'd take it elsewhere for a second opinion on the need for an engine, preferably someone who isn't going to make thousands selling you an engine.
Steve Owens
Signal Mtn, TN
MrTommy
Carson City, NV
Actually, I agree with you about trusting a Ford dealer to replace your engine - provided you need a new engine. Getting a second opinion is paramount though.
I've had good luck with my local Ford dealer doing warranty work, and I didn't even buy the vehicle from them. I think you have to get a 'feeling' for the dealer as to whether you trust them or not. Just my opinion.
DrExpo
Los Angeles
of course a dealer can be trusted to replace the engine - but its more of an issue of do you need one replaced and how well is their staff when it comes to reviews?
i would agree with going for a second opinion. second opinion would give you some idea of what you are really facing OP.
Keepinitoldskool
Miami
0 psi cylinder and scored/beat up cylinder walls, it sounds like it dropped a valve, which requires a new engine. Buy a boroscope and have a look for yourself, it's a small price for peace of mind. They even have ones that plug into your phone
Motorcity muscle
Motorcity
David have you looked online at the dealers reviews in Portland? Guys here are giving good advice to get second opinion with someone you do trust and has good reviews. Harbor freight sells bore scope cheap, could pay for itself with one use. Maybe a friend could give you a hand if your not up to the task.
rjdelp7
2000 XLT
NY
Dealer for warranty work only or you will most likely pay 25% more than a local shop.
joethefordguy
no, it does not require a new engine. that damage is repairable/rebuildable. question is, what does that cost compared to a replacement engine? Prices for both vary wildly across the country, so it depends on where you are.
I've been messing around in this business since I was a teen. whether to replace or repair an engine almost always comes down to cost. There are other factors as well, but almost everything is repairable, including, for example, something as "catastrophic" as a broken block.
FWIW, I do not recommend repairing a broken block, I'm just saying some repair is not necessarily impossible. It's just not cheap. Or wise, for that matter.
jeff kushner
North of Annapolis
A Portland Oregon member who "has always used the Ford Dealer"
Absolutely trust that dealer, and go ahead and give them a decent tip. You should support your local businesses regardless of the cost!
jeff
