Car alarm goes off
Freedomexpo
Hello all. If we lock our expo, but our dog stays in....the car alarm goes off. Does anyone know what is causing this or is there an easy fix?
F
Freedomexpo
First....that does work. But it just seems ridiculous that you need to press that every single time! Who designs this stuff?! It should be a setting that you should be able to set it and forget it.
bwhinnen
DFW
You can set the default on the dash under Advanced Settings -> Vehicle -> Alarm. You can then choose to be asked or to default to either setting.
You may want to read your vehicle owner’s manual.
F
Freedomexpo
It will not default. It resets to all sensors every time the vehicle is shut off. 99whitec5coupe.....funny thing is it didn't come with a manual. I bought it used. Sorry for taking up your precious time....I was under the impression people could come on here to gain knowledge and understanding from others. Keyboard warrior, huh?
sjwelds
Kansas
Touchy touchy.
cfldad
Don’t use your key fob to lock the door. Use key pad on outside of driver’s door (78 together) and doors lock without arming super sensitive security inside.
bwhinnen
DFW
<snip>
What year model? Mine is a 2020 and definitely lets you set a default.
Personally I like it asking as sometimes my teenage Son wants to stay in the car and we still lock the doors. Being able to just select perimeter in that case is handy.
wakeboarder
Fort Lauderdale, FL
Did you try Settings -> Vehicle -> Alarm as suggested above? What options do you see?
You could also try electrical tape over two two sensors in the overhead console.
F
Freedomexpo
Aggiegrad05......does it stay that way? Or does it reset to all sensors every time you turn the vehicle off and then on?
3rd Expyowner123
I’m guessing this is a safety feature to help prevent child deaths from being left in a hot car
cfldad
Could be. My kids set it off a few times until I started using the door keypad. Usually leave it running and them locked up.
