Bilstein 5100 Lift Install
Expedition Dave
A Tiny Little Dot in Florida
I received half of my bilstein order (rear shocks) that I placed on Jan 5, 2021, should I wait to install them when I receive the front struts in 2 weeks? Will it be an issue to have OEM in the front & bilstein in the rear?
It will look pretty wonky, having the rear sitting two inches higher, and could inspire slightly weird handling, goofy collision alerts/radar cruise and reduced headlight vision.
FWIW, I think the best thing you can do right now is find a proper, level place to measure, mark it off a few of the tires with chalk or a landmark, pull all the weight out of your truck, fill the tank and measure it from ground to fender all four corners, than center of wheel hub to fenders or just the latter. Install, drive a few to 50 miles and report your new measurements.
I am also trying to convince management here to sponsor a lift sticky thread...
DWs-TTEB
Evans, GA
Thanks Dave. I will wait the 2 wks for the fronts to arrive. Will do the measurements as well.
MattB9418
VA
Mine is in the shop for full bilsteins, with the larger 275/60/20 cooper at3, pics tonight
DWs-TTEB
Evans, GA
Finally got the front bilstein struts delivered this Monday to go with the rear shocks I got back in March. Ordered all 4 on Jan 5, 21 from 4wheelParts. Now that I have all 4, I will be installing them myself tomorrow. Took the day off from work for it. Will also being doing tire rotation, oil change, & front end alignment. PICs & measurements inbound.
DWs-TTEB
Evans, GA
Just finished installing the set of Bilstein struts/shocks, did and oil change, installed that quick valve oil plug, rotated the tires and did a DIY alignment.
1. watch this video before and during installing:
Set it to #3
Set it to #4
Post struts/shocks install
Before install
r98exp1
