Hoping my new truck can tow this
Fasttimes
Miami
As you stated in your other thread, you planned to travel with 8 people in tow. What does the payload sticker of the new XLT say? My guess is that trailer would have 900lb-1000lb tongue when your loaded for your trip, but maybe not.
shane_th_ee
Seattle
You really need to weigh your new Expedition with all the people in it and a full tank of fuel. The difference between that number and the gross vehicle weight rating of your Expedition will set your maximum tongue weight. (Note that a properly set up weight distribution hitch will transfer 25-33% of the tongue weight back onto the trailer axles...) We are able to get away with a 900lb tongue weight, 6 people and 3 kayaks. That's because we're small people and we took the time to carefully weigh everything, did the math, and swapped our 800lb spring bars for 1200lb spring bars so as to get the proper weight transfer from the rear axle back to the front and trailer axles.
Here's how the math works for us. Our payload is 1600lbs. 1600lbs minus 600lbs of people gives 1000lbs of available payload. 900lbs of tongue weight with 270lbs (30%) transferred back to the trailer gives 630lbs (900-270) riding on the Expedition. 1600lbs-600lbs-630lbs = 370lbs for roof rack, kayaks, etc. Note that to make all that work I did have to be careful to make sure the kayaks I bought weren't too heavy, the roof rack was installed with the kayaks as far forward as possible, etc, etc.
If you're not big people*, I think it's likely you can make that trailer work but it will require some care and attention and trips to the scales.
*If y'all average 200lbs and you have 8 people, 200*8=1600. 1800lbs of payload** - 1600lbs = would leave 200lbs...
**Assuming you didn't get the panoramic sunroof and so have an extra 150lbs of payload
mwl001
Scottsdale AZ
Hi there,
We just upgraded our Expy 2018 to a 2020 XLT 4x4 (not max) with Heavy Duty tow package, it has the 3.73 axle ratio. This is the trailer I would like to tow https://www.jrvcountry.com/rv/2021-VENTURE-STRATUS-281VBH-4796-0
This will work I hope.
Thank you
That’s 5-6 feet longer than what I’d comfortably tow with an Expedition Max, to say nothing of the short wheelbase version. I consider 30ft plus 1/2ton-3/4ton territory, regardless of weight. Lots of factors influence towing safety not just coming in under the max rating.
JasonH
Houston, TX
Hi there,
Thank you
You're going to need to visit a scale. I tow 30+ with a max. It's fine, but I don't think I would want to do it with a shorter wheelbase. If you can get the weights right, a ProPride or Hensley might help. But with the number of people you'll have traveling, I'll be very surprised if you can make payload with enough weight on the tongue. These vehicles can tow or haul, but not both when you're towing heavy. For the number of passengers you'll have, a 3500 van would have been a better option.
