Need Help: Passenger front floorboard water leak
Clayton
Clayton, NC
Hi all, looking for some help from someone who may have had a similar issue. Every time it rains I am getting water accumulation on the front passenger floorboard both on and under the floor mat. I put down some plastic and can tell its coming from dash/ floorboard area, NOT the door or the A/C. Anybody had a similar issue? I've checked several times myself and dealer has had the vehicle 4 times already and can not find an issue. I park on a slight elevation with the front end higher than the rear. Any thoughts or similar experiences/ fixes would be greatly appreciated.
Vehicle is 2020 Expedition
JUST4FUN
Admin
Moderator Administrator
Il
Sunroof drains clogged
wakeboarder
Fort Lauderdale, FL
I believe somebody else had a similar issue and it turned out that Ford left some plugs out. I think the discussion was about a year ago.
Skmcclain
Liberty, SC
I'm dealing with the same thing right now. So I'll be following to see what your outcome is. I have smart liners in and when I took mine out to clean the other day I noticed it was wet. I cleaned my carpets and let dry. When I checked again today it had the same condensation on the bottom side of my mat. I'm gonna take it to dealership and show them.
Alwaysthinkin
Georgia
Be sure to print out the TSB in post ( @99WhiteC5Coupe ) #2 and take with you.
DWs-TTEB
Evans, GA
Check these threads out, has pics & such:
jandrews
Oregon
I have been battling this same issue with a 2019 expedition. Passenger floorboards wet when it rains. First trip to the shop they said it was a faulty AC condenser line and they replaced it. I’m still having the issue so I took it back to the original dealership I bought it from. They said they couldn’t duplicate the leak but believed the AC condenser line to be installed incorrectly and “fixed it”. I feel like this is another shot it the dark because they have no idea where it’s coming from and I’ll continue to have the issue. Following in hopes I can bring ideas to them. My floor gets moldy under my weather tech mats and I constantly have window fog due to the internal moisture.
5280tunage
colorado
I would double check the plugs. Seems a little more rampant than it should be. I believe I even saw similar issues on an F150 forum. I think you have to pull the fender liner out to see in there adequately.
Chromo
I had issues with water on the passenger floorboard and it was not from rain but a bad "T" connection in the windshield washer line on the firewall.
