2010 Navigator Base w/o tow package - charge cable for trailer battery
jruppert
Ludington, Michigan
Hello,
I have a 2010 Navigator without the tow package, so its the 4 pin setup. I recently purchased a 7 pin trailer plug in, tekonsha p3 controller with adapter harness. I have yet to hook everything up but was curious what you guys have done for a charge cable so that I can charge the battery on trailer. What I am sorta curious on is if there is anything already on board that I can tap into without running the connection. I looked in my owners manual and it refers to towing fuses and relays and for whatever reason, my car already has
44​
10​
Trailer tow battery charge relay coil
Just curious if there is a way to tap in...
Thanks!
jruppert
jruppert
Ludington, Michigan
I did a google search with the correct 'search word' and found some info from this forum. For some reason, the search function wasn't allowing me to find what I was looking for.
Thank you
Greg Coleman
Southeast Michigan
I can't directly answer your question. But the 7 pin does have one listed as "hot". That should be the one that will charge the trailer battery when connected to the vehicle.
I use a small solar panel and a Battery Tender solar controller to keep mine topped off.
Langer
Chicago
have a link to those?
