MrBlargMan
I would replace your PCV valve (valve cover) and have somebody drain your cooling system and refill it with an AIRLIFT. Excessive crankcase pressures will always cause oil leaks and it also sounds like you could possibly have an air pocket hanging out in your cooling system. The AIRLIFT pulls a vacuum on the cooling system and then your engine coolant is sucked in eliminating possibilities of a stubborn air pocket. None of your described symptoms scream head gasket to me.
