2017 Expedition Positive Battery Terminal
GlennSullivan
NY & FL
Went to start my truck the yesterday and it was completely dead. Popped the hood and checked the negative and positive terminals. To my surprise - shock really (this is a 2017 with 33,000 miles) the positive terminal was corroded in half. In the last 5 years the terminal material has been getting thinner and thinner on Expys, I still own a 2011 and had a 2914.
So Im thinking N/P I have 7 year Ford Premium Care extended warranty. I look up the details and it says battery and battery terminals and cables excluded. OK still N/P how much can a replacement terminal / cable cost?
Well what Ford sells is not a “battery cable / terminal. it is a positive power harness that has about 10 connections throughout the engine bay and costs over $400.00 !!!!!!!!!!!!
Anyone have any experience with this and more specifically fighting Ford on Premium warranty coverage on this?
Here you go: https://static.nhtsa.gov/odi/tsbs/2019/MC-10164497-0001.pdf
I bought a new 2015 Ford Expedition Expedition and have had it serviced at the dealer. After one of their multi-point inspections, I checked under the red vinyl cover for the positive battery terminal when I got home. It looked like a science project.
I removed the connector and cleaned everything very well. Periodically, I checked the connectors and clean them.
After I replaced the original battery with a new Motorcraft battery (same specifications) - the corrosion stopped. I suspected I had a battery that was leaking fumes or something, which gathered under the red cover.
Just replace the connector with one listed in the TSB above.
Good luck.
PS - I bought the Ford Extended Warranty Premium care but did not invoke it for the terminals (or the base warranty). I have found out that Ford excludes numerous parts from the extended warranty, and the dealer must check the part number in their computer to see if it (and the labor) is a covered part under the extended warranty. I’ve had a lot of poor service from three different Ford dealers, including the selling dealer, and that is what will prevent me from buying another Ford.
GlennSullivan
GlennSullivan
NY & FL
Thank you VERY MUCH, you just saved me alot of expense and grief. I agree that the positive battery terminal / connector is totally and completely over complicated.
Retiredusps
N.J.
On my 2005 i cut off the factory terminal AND LEFT ENOUGH OF THE COPPER TO DRILL A HOLE AND USED A MARINE TERMINAL REPLACEMENT. NICE BRASS REPLACEMENT, THAT WAS ABOUT 3 YEARS AGO STILL GOING STRONG
GlennSullivan
GlennSullivan
NY & FL
I had to replace my neg term at 36,000 mi it was so bad. The pos term was slightly oxidized and I cleaned it and coated both terms with NoOX paste.
here's the p/n for pos term BT4Z-14450-AA
neg term BT4Z14450BA
here is a quality terminal mfg https://royalpowersolutions.com/products/battery-power-electronics/battery-terminals
What Year Is Your Expedition? I went to the dealer with the NHTSA SSM document provided above and they looked it up while I watched. SSM 48123 which says you can replace only the terminal only with part number BT4Z-14450-AA is not applicable to 2017 Expeditions.
GlennSullivan
GlennSullivan
NY & FL
FYI. The 2017 terminal has a battery monitor built onto the terminal base.
1970Maverick
orlando, fl
Original owner of 2017 XLT RWD no options.
I don't know anything about a battery monitor being part of the terminal, maybe the limited has it but my terminal does not.
Call Royal power maybe they can answer your ???
Michael McC
Corpus Christi
I had the green fungus on my positive terminal. The cause was a cracked battery case at the base of the terminal. I cleaned it up, replaced the terminal (see photo in post #7), and sealed the terminal base with JB Weld. Worked well enough until new battery time.
Andy Rubalcaba
Riverside, CA
I almost went this route but fixed the terminal issue I was having on my '08 ( actually it was just the bolt and nut that give the terminal clamp force, I found a different bolt and nut to use ).
I gotta say, the marine terminals looks nice, I still might change mine over to that one day.
@OP, make sure to put some dielectric grease on the terminals and do a monthly cleaning yourself. Just use a wire brush, take off the cables and scrub everything, then use either the grease or you can buy a lubricating spray ( Noco, CRC, what ever brand you want ). You'll want to prevent corrosion on your own, dielectric grease is great to keep around and it's only a few bucks for a tube of it.
GlennSullivan
GlennSullivan
NY & FL
I'd like to provide an update on this. As others suggested This situation was caused by a leaking positive battery post that destroyed the positive terminal even though I cleaned it at every oil change (4,000 miles).
My 2017 Expy Limited was covered by Ford Premium extended warranty. They told me that the terminal is not replaceable by itself - have to replace the entire power harness and refused to cover it under warranty. Quoting me "about $800 plus tax) to install the new power harness not including another $140 for the battery.
Others here advised the terminal is replaceable, so I compared the positive terminal attached to a new entire power wiring harness for the 2017 as well as the recommended individual part number positive terminal. They are both identical, though the dealer and Ford computer that they are not compatible.
The positive terminal has the battery monitor as well as a secondary positive power cable bolted vis individual posts and nuts for each. The main positive power cable is crimped to the terminal and not easily removable. The main cable is also too short to cut off the old terminal, restrip the cable and crimp on a new one. BTW The negative terminal has 1 easily removable bolted on cable, which could certainly have been done with the positive terminal.
I unbolted the battery monitor, and secondary cable bolted to the positive terminal and then carefully cut the back of where the positive terminal is crimped to the main power cable and removed the terminal. I cleaned up the main cable and installed and crimped on the new terminal along with several pieces of shrink tubing.
Installed a new battery (BTX-65-850) to replace the leaking (BTX-65-750) one, reconnected all the terminals, sprayed on some terminal protectant and all is well.
I'd like those of you that have had the same issue to post in this thread as I'm going to have a further discussion with the Dealer / Ford and NTSB, who already has a notification open on this situation.
20210827_095041.jpg20211022_144234.jpg20211022_145212.jpgView attachment 70862View attachment 7086320211022_151102.jpg20211023_123419.jpg
JustHarsh
Minnesota
Same issue with the terminals; heavily corroded. I didn't have to replace the terminals (although I did order them). I was certain I would need to replace at least the positive. I used baking soda and water to get most of the surface corrosion removed. Terminals still wouldn't budge from the battery posts. I then sprayed Blaster PB on the terminals and let it soak for about 30 minutes. Some light tapping with a rubber mallet and gentle prying with a standard screwdriver I was able to loosen the terminals from the battery posts. I used a wire brush and some steel wool to clean up the terminals. Applied a generous amount of anti corrosion gel to new battery posts and terminals and was back in business.
GlennSullivan
GlennSullivan
NY & FL
The battery case under the positive terminal may be cracked, as mine was which allowed acid to seep and cause the severe terminal corrosion, even though I was cleaning at each oil change.
Keep a close eye on it as you may need to change the battery.
JustHarsh
Minnesota
I swapped out the battery during this process.
EngineerMike
ca
I haven't had this issue w/my 99 Gen1, but had the same problem w/2012 Nissan Frontier, positive post corroding ridiculously & killing a bank of fusible links bolted to the +term. Battery sensor is 3-wire type w/a CT coil wrapped around the negative cable. Charge voltage was variable starting at 13+ on startup but dropped rapidly to 12.3v which won't charge a battery. After the corrosion issue had me stall out while driving, finally having to be towed to dealership the dealer jackassed around under warranty replacing the PDM, ECM & finally the fusible links, I had the corrosion problem back within weeks. I switched to AGM type battery, no more corrosion but the more expensive battery still died after about 2-2.5 years which is ridiculous. I unplugged the battery sensor and charge volts are steady state at 14v, battery is happy & long lived. Car mfgr's dial the charge voltage down to battery killing levels for less drag on the engine so they can report higher EPA mpg & higher fleet mpg. Wife's '16 Subaru has same b.s., low charge voltage, killing batteries in less than 2 years, corrosion on pos terminal.
I suggest unplugging the battery sensor on all vehicles, especially in winter but no reason not to do so year around, low voltage kills batteries. Pretty sure that applies to lithium also.
princered72
Started having an issue with my 14 Expedition Limited. Sitting over night and go to start it and battery is drained. Thought is might be my phone charger or dash cam but even with those unplugged still drained the next day or turns over very slow. Noticed the green corrosion on positive terminal. Cleaned it once about 2 weeks ago and back in force again. Had the battery checked and it is ok. I am going to check the battery for any cracks also and the cables
