Rear AC not blowing
Craig Menn
San Antonio
My rear air isn’t blowing at all, anybody got any input? Fuse is good. Actuator working properly, just won’t blow.
Hamfisted
Ft Lauderdale
You're gonna have to pull the panel so you can check for voltage at the blower motor. You're saying fuse #11 under the hood is good ?
There's a speed control resistor back there in the box by the motor too. They burn out just like the fronts do. See if you're getting voltage at the resistor. Then the motor.
Rear Speed Control Resistor at Rock Auto
Craig Menn
Craig Menn
San Antonio
Thank you. That’s what I needed to know, wasn’t sure if the rear had separate resistor.
texas
Thank you. I was getting back on here to tell you I bought a mutlimeter and was able to pin it down to the blower motor. I replaced the blower and it works like a charm again.
