power loss and wrench icon
gkretro
New Mexico
This just happened to me on 2017 truck. Its a 2 wheel drive with about 62K on the clock. I was on level ground going about 30 mph, had a very sudden power loss and the yellow wrench icon appeared with "see manual". I was able to pull to side of the road, shut the engine off, counted to 5, restarted and everything was fine. I'm going to dig out my Scangauge II and see if I can read any codes. Searching online indicates it may be the throttle position sensor. I searched the pdf for the owners manual and "wrench" find entries about changing tires, so not that helpful. I'm guessing other folks have seen this besides me, any feedback greatly appreciated.
G
gkretro
New Mexico
Update: Nothing on my Scangauge but apparently restarting the engine may clear the codes. I found several posts relating to throttle body or thottle position sensor. The owners manual indicates a generic "powertrain fault".
Adieu
SoCal
Did you lose power steering? On a 5.4 that would sound like a throttle body issue tripping the ECU up.
For an ecobeast, not sure... maybe look on F150 forums? They have a LOT more ecoboost experience and info.
Turning off the engine often resets the throttle body, and allows for an engine re start and normal operation. There is a good chance the issue will return (with family on the expressway?).
I would have the throttle body replaced or replace it. Ford had issued a TSB (I don’t have a copy) for the 2015 - 2017 Ford Expeditions and problems with the throttle body.
There are a lot of posts on this forum, with good information, regarding the problem.
Good luck.
G
gkretro
New Mexico
I found more posts on various sites that point towards the throttle body so that's where I'm going go.
Andy Rubalcaba
Riverside, CA
it's a 2017 so it'll be an ecoboost.
G
gkretro
New Mexico
Update on this issue:
Took the car to a shop I trust. They found no codes stored even though I had failure happen on the way to their shop. They were unable to duplicate the problem and were about to give up when they experienced the problem. Again, they found no codes so they drove it some more with a reader attached. Had the problem happen and basically pointed to either the throttle body or PCM. The PCM is special order and over $1K, throttle body is cheaper and in stock so we're gonna try that. Another possible cause is supposedly low battery voltage. Battery is the original and marginal so I'm replacing it, mostly so I don't have to worry about it.
The issue of codes not being stored is kind of worrisome, I'm really hoping its the throttle body since that's a known issue with several Ford engines.
A weak, or failing battery, can cause all types of electrical issues in today’s modern vehicles. You’re smart to replace the battery.
Let us know if the problem continues - which will probably be a failure of the throttle body.
Good luck.
G
gkretro
New Mexico
Final update: Shop replaced the throttle body, drove it around w/o further problems. Not too surprising given the history of issues with Ford throttle bodies. I'm kind of surprised that no failure codes were stored, given the severity of the problem. But I drove about 100 miles over this weekend towing a cargo trailer and had no issues, so I'm pretty happy.
Langer
Chicago
Pretty sure I just got bit by this bug. 71000 miles on 2017 XLT 4x4. Truck entered wrench mode and no throttle response halfway between STL and Chicago in the middle of nowhere. Pulled off onto the grass on the side of the interstate to make sure I didn’t spill the fluids/oil, all were fine. Nothing running hot, but truck idle was extremely rough. Turned off and turned back on, made it the rest of the way home without issue. A few bonehead moves:
First, I accidentally left my Bluetooth OBD2 scanner in my FiL’s truck, so I couldn’t confirm anything, but based off all that occurred, it vividly reminded me of this thread.
Second, this throttle body was sitting in my cart at parts.ford.com for weeks so I could have one as a spare in case I ever got stranded by something like this, and I just never pulled the trigger.
Got home without further incident and used my other scanner to check, and, as with the others above, no codes.
Hopefully this is actually the problem. Will update.
G
gkretro
New Mexico
The whole thing about no codes is kind of silly. If an error condition is happening, which makes the wrench icon come on, a code should be logged.
Adieu
SoCal
Throttle bodies don't code for some reason
Then again, it might be because the whole damn OBD system is for failing people on smog inspections, not for ECU diagnostics
barrydu4
Louisiana
I have a 2017 Ford Expedition Ecoboost V6. It did the same thing to me. They said it was a sensor in the transmission. Supposedly they used the same transmission as the Ford trucks and they have a recall on them. Just my two cents.
According to the NHTSA website, there have been no safety recalls issued for the 2017 Ford Expedition.
Who are “they”?
Can you provide more information on the recall, and perhaps check your service invoice?
Langer
Chicago
Got the new one in. Pretty easy job, you could definitely do this on the side of the road if you HAD to. 8mm deep socket/ratchet took care of the hose clamps and throttle body bolts.
The old one was pretty oily, more than I would’ve expected considering I have a catch can, but I guess I have no frame of reference for that thought.
Hope the problem is fixed.
catmandu
Sierra Nevada
Oh you can definitely do it on the side of the road / hotel parking lot. With a brand new cheap Chinese socket set. In Laramie, WY while driving from MD to NV while towing a fully loaded 16' enclosed trailer. :rolleyes:
Thank you interwebs for alerting me to this problem that happens around 60-70k miles, it seems.
