no phone, need apim
HavasuMike
Lake Havasu City, AZ
My Sirius is working but not the phone or Sync (2016 XLT). I took it to the dealer yesterday and they told me I would need a new APIM module for the wonderful price of $1000. I'm not sure if I can get it done somewhere else for a lot less money but i can buy a handsfree unit for $35. Has anyone had any experience with replacing an APIM module? The radio and radio controls work fine.
I had this post in another area and was asked to move it.
Yupster Dog
Moderator
The new member section is to get to know the member who started the thread.
Also starting a new thread is better for getting results rather than tacking on to the end of a old thread.
I hope someone can help you with this problem.
Boostedbus
My APIM has finally arrived at the dealership. I’m taking it in Tuesday morning for it to be replaced under warranty. It has been ordered since July because of the chip shortage. Mine is a 2017 XLT. Not sure you can find one anywhere in stock because they have been on back order and when one comes in they are already spoken for.
Fastcar
Army
FL
Must be different models for different years that is the problem. I've had 2 installed in mine in the past 3 months. I believe they were shipped out of a company in NY
Boostedbus
Wow…. I hope I don’t have to take mine in anytime soon again for the same issue cause that would just suck! It sounds like we are dealing with inferior parts if that’s the case.
kenagain
I'm still waiting...also since July.
1970Maverick
orlando, fl
My 2017 has the same problem and I only care about making handsfree phone call so I'm looking at a visor mounted handsfree bluetooth speaker like this one it's under $40.
This is one of the problems with modern cars...TOO much electronics that interface with more electronics. No way would I pay $500-1000 just to make phone calls.
Retiredusps
N.J.
I didn't know what it was googled it a company called 4dtech has them you have to supply vin and they will program it for you looked alot cheaper About $400.00 if it is the one to fit your expy
Yupster Dog
Moderator
I second what @1970Maverick said and the hands free unit in his post i bought for my sister (4 hours of comute 2 each way) not only does it work and have long battery life but it also cuts itself off and on as you leave and come back to the vehicle so you never have to touch it once set up.
She loves it so much that i bought one for a spare for me if i have to drive another vehicle. Well worth the price if you factor in that its half of what a ticket is for having your phone in your hand. I bought it back in June right before the law came into effect here in VA.
H
HavasuMike
I already have a handsfree unit that I bought for my Jeep. I may have to get another. It was only $30. I found the APIM module online for $330 and change. Does it have to be programmed after installation? Where is it located in the vehicle? How tough is it to replace? Any answers to these questions will be helpful in making my decision as to what to do.
Boostedbus
From what I’ve gathered it is supposed to be located right behind the back up camera screen. There’s probably a You Tube video out there on replacing it.
H
HavasuMike
You are not going to believe this. Yesterday while driving, I received a call on my visor hands free unit. This time my radio turned off which it hadn't done before. After I hung up from that call, I pressed the voice button and it worked so I made a call and that worked. It's been about 2 months since it quit working but hopefully it will keep working and I won't have to spend the money to have it fixed.
H
HavasuMike
Bad news. It stopped working again. I was listening to the LA/SF playoff game when I got a message on the screen. It said to start the engine or remove the key. It didn't work after that. It apparently has something to do with the battery being low. The first time it happened, I had removed the battery ground and it went out. I guess it's back to the visor mount until it comes on again(hopefully). Anyone have any thoughts or experience with this kind of trouble.
1oldtimer
Va
By any chance, are you using an aftermarket USB/Cig.Lighter charger? I have had them interfere with bluetooth in other vehicles.
Motorcity muscle
Motorcity
Had a phone charger interfere with the tire pressure sensors on my '07, would trigger dash light for low tire.
