Could it be the voltage regulator?
Fordfangirl4life
Atlanta, GA
I have a 2001 expedition, 5.4 Triton, 2we. After replacing the alternator, battery and battery cables, all interior and exterior lights "flicker", for lack of a better word. They rapidly get bright then dim. On absolutely clear nights it's not really an issue, however, I live in north Georgia where absolutely clear nights are not the norm, could it be the voltage regulator?
Hamfisted
Ft Lauderdale
What brand alternator did you use, and what amperage ? Did this fluctuation start just after the new alternator install ?
Dennis_H
DFW, TX
Can you monitor the voltage output when it's running? See what it reads from odb port. I had replaced one in an escape this year and it was bad and overcharged. Would shut down dash and other problems. That one you have to remove axle and motor mount to change. Will only do new Motorcraft in that vehicle. Expy is a piece of cake, so with the risk for reman.
Hampton, VA
arent the voltage regs internal on stock and replacement alts? i had the option and got internal reg for my 370 alt
